Home > Maintenance & Modifications > Doors sticking out
Joncorry
 2003 Defender 110 Td5 G4 Challenge Tangiers Orange
Doors sticking out
When I picked up my latest 110, I noted the previous owner had used adhesive draught excluder on the front door tops and that the seals were past their serviceable best.
I’ve bought new seals and removed the draught excluder but note there are large gaps towards at the door tops now.
Is there a delicate/proper way to fix this or is it just a case of using a large tapping stick to bend them back in?
 2009 90 commercial.
2003 110 G4 used in 03 and 06 events - its well travelled.
2002 Range Rover G4 Event car (Australian leg)
2008 Discovery 3 G4 UK Selections car
1968 Series 2a
Post #972165 23rd Nov 2022 6:22pm
The usual approach is to adjust the hinges and striker to get the bottom half of the door to align as well as possible and then if the top is still sticking out bend it carefully into shape (I tend to wind the window glass down to be on the safe side, although I have never heard of anyone breaking the glass doing this.
It isn't clear from your photos if the lower part of the door is fitting properly.
Landrover doors seldom fit well, and the door-to-panel gaps will usually be spectacularly wonky. It should be possible however to get them to shut flush and to get the waistline aligned.
Post #972166 23rd Nov 2022 6:26pm
Joncorry
Thanks for the advice, the bottoms do need fettling too. I suspect that due to the very worn catch screws, they’ve been adjusted one time too many. The strikers were also very worn so I’ve ordered new.
👍 2009 90 commercial.
1968 Series 2a
Post #972169 23rd Nov 2022 6:55pm
Joncorry
Weather held off for five mins today to allow me to ratchet strap the door tops. Handily, the bottoms are sticking out a little so it should allow them to come in a little.
New strikers arriving soon so that should allow me to fettle the bottoms.
 2009 90 commercial.
1968 Series 2a
Post #972252 24th Nov 2022 5:21pm
