Home > For Sale & Wanted > [Wanted] 300 Tdi EGR valve - any condition
donmacn
Hi folks,
As the title says, I’m looking for a 300Tdi EGR valve that I can refit to a car for MOT purposes. I know it’s a common enough thing to remove, maybe not so common to replace….
It doesn’t even need to be working - just something that “looks” like an EGR valve….
I’d refit the original, but it was a right Censored Censored to get off, and Mr Angry the grinder came out to play….
Thanks Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #971779 20th Nov 2022 10:51am
htb2
Wales
Donald, how much of the system are you after. On my spare engine there is EGR valve, flexi pipe and inlet pipe to suit. Would have to try and unbolt from the turbo, might be easier said than done.
Edit, no idea if it works or not, but as you say your not bothered.
David
Post #971822 20th Nov 2022 6:37pm
donmacn
Hi David,
Thanks very much for replying - to be honest getting the valve and the inlet pipework would be perfect. The car’s in a shed 20 miles away, but I do have a vague memory that the hose got cut, so if you can manage that I’d really appreciate it.
I’ll send a PM.
Ta
Donald Donald
in the past..
Post #971832 20th Nov 2022 8:01pm
