![]() | Home > Puma (Tdci) > Nanocom - As10 |
It's more likely a blown fuse than a fault with the AS10. There are several beyond the obviously marked that relate to the alarm system, so I'd recommend checking all in the fuse box beneath the steering wheel as a first step.
Have you changed any bulbs recently such as the indicator side repeaters or replacing the interior lights with LEDs? Does your radio still work? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Yesjus Member Since: 19 Sep 2022 Location: Surrey Posts: 80 ![]() ![]() ![]() |
I did recently change them to LED interior bulbs but they weren’t working in the auto position before this.
They work normally when in the on position so didn’t think a fuse was the culprit? |
The auto setting on the interior lights is a separate feed controlled by the alarm and is on a separate fuse, so yeah, still could be. Darren
Good stuff, will give that a go then. Don’t suppose you have any idea on the fuse location?
I think F2, F8 and F30 are related. Also check whichever one is for the radio. Darren
Checked all fuses and all good so pointing towards them being turned off in the AS10 at this point?
Whilst not impossible, that seems pretty unlikely, to be honest. Having said that, I'm all out of other ideas now
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Me too!! Only reason I’ve come to this conclusion is because of previous threads on the forum suggesting it’s a setting in the Nanocom that has the ability to switch settings on the interior lights.
Even though they are in the TD5 forum section, I’m assuming/hoping it’s the same for the Puma? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4291 ![]() ![]() ![]() |
There is a setting in the Puma AS10 for the interior lights, but unfortunately I'm not near to you. 2007 110 TDCi Station Wagon XS
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Where in Surrey?
I'm in greater London not far from Hanger Lane and have a Nanocom |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2428 ![]() ![]() |
What year is your Puma Yesjus ?
Depending on the year you will have a 10AS or a ALM unit. 10AS is green, ALM is black, you can see them by removing driver footwell speaker and looking slightly upwards from the footwell. The good news is that Nanocom state they support both units and have the ability to test the interior light function and configure the interior light function. Points to note, The Nanocom supports the 10AS unit well. It supports the later ALM CH serial number units but there have been issues with its use that requires re-syncing with the engine ECU after changing the indicator flash on alarm setting. To do a resync the Nanocom requires the latest 1.36 beta 2 update. So just in case changing the interior light setting requires a resync be prepared, else you won’t be able to start the vehicle. The DH version of the ALM unit has not been validated by Nanocom, as they have not been able to obtain a unit, however they think the Nanocom will work the same as with the CH versions. This may be true but the DH version does have some differences in hardware so I’m more cautious on its use with this last version of the ALM unit. One last point to note is that it has been reported that interior lights fitted with LED bulbs can damage the ALM CH version circuits that deal with interior lights. Guides https://www.nanocom-diagnostics.com/upload...0Guide.pdf https://www.nanocom-diagnostics.com/downloads/preview/alm-ecu |
mata Member Since: 24 Jan 2014 Location: Manchester Posts: 153 ![]() ![]() ![]() |
I had a similar issue recently, my interior lights weren't triggered by any door other than the drivers door. The door switches and wiring was all good, tested with a multimeter into the relevant piun into the 10AS. The 10AS was seeing thedoors open as it would beep the horn if i tried to lock the car with the fob and a door was open. I borrowed a Nanocom and paid for the 10AS unlock code for defender. I went through the menus , swapped the interior light settings around, but the looked right so I put them back to how it was origionally and it started working again, so a bit of a mystery. I have swapped to 3 x Mud UK LED interior lights incase thats relevent.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1282 ![]() ![]() ![]() |
I recently fixed my door light which was down to numerous wiring issues, which I knew. Went through it all meticulously and now it all works fine.
One thing to note is that the lights don't stay on forever and if any of the switches or wires are shorted to ground the light will be off and stay off (unlike the olden days when it would drain your battery. My bet is that it is s wiring/switch issue |
Thanks for the info! I have a 2008 110. I think I have the green one. I did recently fit LED interior lights but they work fine in the permanently on position. It’s just the “courtesy” position that doesn’t work currently. |
