Home > Puma (Tdci) > Auxillary power on 13Pin Trailer Fuse.
Polarismd
Good Evening,
I have lost auxillary power (fridge etc) on my caravan.
Wiring appears OK.
Does anyone know which fuse (if any) to check on 2008 Puma?
I cannot find anything online and I do not have wiring diagram with me.
Thanks in advance.
Chris
Post #971361 16th Nov 2022 6:22pm
90 Dreamer
Generally the Aux power is from a direct feed off the battery as it isn't part of the std fit trailer wiring (7P from factory)
Most likely it will be separately fused directly off the battery??
Post #971383 16th Nov 2022 9:15pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
If its the factory 13pin wiring kit, they'll be a feed from the battery to a relay under the passenger seat. The relay is triggered from an ignition live behind the dash.
Worth checking whats under the seat and if you can find that relay.
Post #971393 16th Nov 2022 10:10pm
Polarismd
Hi, I don't have any obvious connection to the battery.
I will just have to check all the fuses one by one.
Thanks anyhow.
Chris
Post #971394 16th Nov 2022 10:11pm
Martin
Site Admin
Is this the permanent (pin 9) or ignition feed (pin 10)?
The ignition feed is not fused as part of the vehicle loom, it is a retrofitted fuse and relay block in the battery box.
The permanent feed is from fuse 2 under the RH seat on a 2.4 Puma.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #971395 16th Nov 2022 10:22pm
Polarismd
Hi
Thanks, that's very helpful.
It's the permanent feed. I will check that one.
Regards.
Chris
Post #971397 16th Nov 2022 10:27pm
