![]() | Home > Puma (Tdci) > no handbrake light |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3643 ![]() ![]() ![]() |
I would start with the switch itself, mounted on the side of the handbrake lever. You can see it after pulling off a bit the handbrake boot. Check that it is making a good contact to earth with the handbrake on. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
miker916 Member Since: 25 Oct 2022 Location: Fife Posts: 64 ![]() ![]() ![]() |
Hi Dinnu,
Thank You, looks like i need to order a new switch, mines is missing its plunger completely. Thanks Mike |
My shiny new switch arrived so i thought id nip out and fit it, will only take 5 mins right?
Who at landrover thought it would be funny to put the screw heads on the inside of the handbrake? On opening my shiny new switch i find out its backwards so it wont fit. Looks like you get left hand a right hand drive swictes. Could someone confirm the right hand drive part number for a handbrake switch please, this is what i mean by my new switch being 'backwards', new part on the left exiting broken part on the right: ![]() Click image to enlarge |
Did you get part #2?
https://www.lrworkshop.com/diagrams/land-r...ever_52916 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
i did, rimmerbros have just replied to my email saying only the left hand drive part is now available - FFS!
never removed the switch, but possible to mount 'up side down'? or the wire will foul? Or something else? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
the original connector was to long to fit the switch upside down so i ended up cutting it off and replacing it with a much shorter spade connector, all fitted and i now have a dashboard handbrake light
![]() Cheers Mike ![]() Click image to enlarge |
