![]() | Home > Off Topic > Bolts for back of wood / coal burner |
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 234 ![]() ![]() ![]() |
I’m no expert but I do know stainless is tempered at silly temperatures.
Not sure if the Chinese do the same as any pressure you put on the head wreaks them. The manufacturer should be able to tell you what they were tempered at. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543 ![]() ![]() ![]() |
I'd have no hesitation in using 304 grade fastenings for your application as it can be used up to 870 celsius although you will see the tensile strength starts to reduce after about 400 celsius. Also bare in mind that between approx 400 and 800 celsius it will not be as corrosion resistant as it is at 20 celsius.
Not sure what temperature your Aga will be at the chimney flue but maybe worth checking with Aga Service. Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
wrcarter Member Since: 14 Jan 2021 Location: Laois Posts: 45 ![]() ![]() ![]() |
Yes I would agree with stainless will be fine but I would use some copper grease or anti seize just in case and to aid removal next time.
Standard bolts would probably be fine in that application too. 1989 Land Rover 110 CSW |
