![]() | Home > Tdi > 300tdi bull horn leaking/removal |
jnglmstr Member Since: 03 Aug 2015 Location: Dorking - Surrey Posts: 14 ![]() ![]() ![]() |
My '96 300tdi just failed its MOT on an exhaust gas leak. Turns out the bull horns leak where they enter the turbo. Oh joy.
Can they be removed in situ or am I facing the removal of the entire turbo? Any tips with regards to sealing them up? I believe they are simply pushed in? Many thanks, R. |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917 ![]() ![]() |
Hi, they are a simple push in. I "might" have put a smear of exhaust sealant onto them when I fitted my new turbo and manifold, but I can't really remember.
As they fit over studs in the head, and assuming the studs stay in place (which they don't always) then I think you'll be looking at taking the turbo off - or at least pulling it back off the head. It might be advisable anyway so that you could get a new gasket on there, on the basis that disturbing the 'old' one might make it less likely to seal on the refit. HTH Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
I wouldn't disagree with any of that, but if the issue is just the bullhorns it 'might' be possible to remove and refit them with the turbo still connected, just pulled back away from the head and tied off.
I'd agree, if the horns put up a fight then getting the whole unit off and onto a bench would be better. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
