![]() | Home > Maintenance & Modifications > Cubby box sizes |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yes, those factory fitted with the Alpine sub are shorter than standard ones. Darren
| Sussex110 Member Since: 18 Jun 2021 Location: Sussex Posts: 23
Perfect. Thanks Darren, now just need to find one!
| balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 196
Can you not put it under the second row seats?
| Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683
https://www.ebay.co.uk/itm/403711583496?mk...media=COPY
Top left is a genuine subwoofer cubby, you can identify them by the side section of the box where it transitions from the cup holder to the front face of the box - the factory fitted subwoofer cubbys have a slightly protruding lip. You just have to buy all six to get it! |
I've been reading the various threads about other locations and have been looking in to below the rear seats
Excellent info on how to spot one Oldowner!! I'd poured over photos and not noticed that, thanks |
| Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 435
It's probably also worth noting that the factory subwoofer is noticeably thicker than the aftermarket subwoofer. The reason being that the aftermarket Alpine sub has the crossover and its controls separate, while the factory unit does not.
Factory sub: https://www.dynamicsounds.co.uk/image/cata...-image.jpg Aftermarket Alpine: https://www.dynamicsounds.co.uk/image/cata...1200-1.jpg Aftermarket Alpine sub mounted on to a non-sub cubby that is mounted a few inches rearward due to the parking-heater box underneath: Click image to enlarge EDIT: edited several times trying to get pictures correct... Roaming around 🇳🇴🇨🇠|
Thanks Angus_Beef, that's definitely worth knowing. Thanks to the tip on how to spot one from Oldowner I have found one, just waiting for confirmation it's still available!
Using the slimmer version and sub cubby would be a good combo |
| All times are GMT |
