![]() | Home > Puma (Tdci) > Immobiliser Issue? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
some experts in the field will be along in a bit but if I remember correctly:
Disconnect both battery leads and hold them together whilst repeatedly depressing brake peddle, this somehow resets the alarm. Reconnect everything making sure the terminals are properly seated and tight. Press unlock on fob several times to re sync the fob to the module Hopefully it will work..... Good luck! Keith |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2459 ![]() ![]() |
Fob re sync procedure
With vehicle doors closed and unlocked ( I leave a window open) take new battery out of fob and then hold both buttons down for 10 seconds to drain residual power. Battery back in then press lock four times and unlock once. That will sync the fob back to the ECU. Note, an indication that fob battery is getting low is the red alarm light on the dash has remained when you have been driving the vehicle. If not fixed once fob bat and re sync has happened, do all doors central lock when vehicle is locked with key. If not then potentially door wire is broken and blown 10AS alarm fuse. Another potential issue is the ignition switch is faulty. However I think it’s the fob batt and resync issue, make sure new bats don’t have plastic cover on and in correct way around. Plus only have one with you and on key ring when starting as fob needs to be near coil by ignition to work well and having two fobs in vehicle can confuse it on occasion. |
106Lad Member Since: 29 Oct 2021 Location: Northern Ireland Posts: 28 ![]() ![]() |
Update : I threw the defender on the charger as I'd been messing about with it and left it a few hours. Strangely seems to be sorted?
Fob works and it's starting and light goes out?! |
Sounds like your fob battery was low/ dead, replacement has worked and so has re sync and now all ok. So expect all will remain ok.
Your main starter battery is very unlikely to have caused the issues you highlighted, more likely co incidental during your endeavours to rectify the issue. |
