Home > Off Topic > vw Polo - anyone want to hazard a guess...
Caterham
about a month ago the wife abandoned the car up the road as it stopped running.
I went to recover the car later that day - started no problem and has been fine until this morning.
wouldn't start - just turns over (doesn't sound like the battery is on it way out or anything like that).
left it half an hour and it started fine - thought I'd reverse it off the drive and take it for a quick drive but it stalled - could have been me but suspect it was the car - and now it won't start?
will try it again later Confused
no MIL light or anything - any pointers?
Post #967993 17th Oct 2022 11:25am
landy andy
Check fuel gauge, and air filter.
Is there an immobiliser light?
Post #968006 17th Oct 2022 12:42pm
Caterham
Checked the fuel guage (full).
Not checked the air filter (yet) but I don't think its too old.
RAC just been round and reckons there might be a problem with two injectors.
Thumbs Up
Post #968023 17th Oct 2022 2:10pm
landy andy
I very much doubt fuel injectors would be irregular. They work or they don’t. It wouldn’t be fine one day, not the next, then ok again in my opinion. Possibly the supply to them.
Post #968084 17th Oct 2022 7:32pm
Ianh
A little more info would help
Is it a diesel or petrol engine ?
What year is it ?
What size ?
When was the fuel filter last changed as that’s a relatively low cost quick replacement to try.
Post #968094 17th Oct 2022 8:49pm
Caterham
1.6 diesel. 59 plate.
from a very respected mechanic / engineer - 'doesn't sound like the injectors', or at least not for the reasons that were suggested to me (the inconsistent live data).
seems fine again now. I do need to check / replace the fuel filter but pretty sure its not old.
reference the injector(s) not working they are known (generally speaking) to stick - I would therefore describe this and 'on its way out' as it starts to stick more frequently. so I guess you could describe this as 'do or don't work' or as 'on its way out' ?
the odd thing for me is a lack of MIL indicator?
Post #968167 18th Oct 2022 2:23pm
Ianh
Have you your own OBD2 reader, you could be getting Diagnostic Trouble Codes without the MIL light appearing on the dash. Noting something like a dirty filter is unlikely to trigger a DTC.
Running a bottle of forte specialist injector cleaner in half a tank of diesel, especially after a diesel filter change will help clean up the injectors, noting some fill the new filter with it prior to fitting so the injectors get a good neat dose. https://www.forteuk.co.uk/product/diesel-s...r-cleaner/
Post #968210 18th Oct 2022 5:46pm
Bundy
Ideally get it read with VCDS and see what, if any, codes are there...much easier to diagnose that way.
Our petrol Polo ran very iffy when an injector went down, code found and second hand one fitted...all been good since...fingers crossed!
I have VCDS if you anywhere near Congleton!
Al
Post #968265 19th Oct 2022 9:47am
Procta
Re: vw Polo - anyone want to hazard a guess...
might be the crank sensor acting up, My dads jeep would cut out and then decide to start again after a while. Nothing ever flagged up on the dash, might be worth a punt. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #968471 20th Oct 2022 7:16pm
Procta
If its anything like the peugeot 306 HDI system, the ecu would put the car into either a limp mode or just not start at all. Thats if the fuel pressure is failing Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #968473 20th Oct 2022 7:19pm
LiftedDisco
When you say it stalled and wouldn’t restart, do you mean it turns over but won’t fire?
I think the 1.6 Polo has a fuel solenoid on it - this sounds like either solenoid failure or a loose connection that makes but then breaks (hence the non-starting).
Hope this might help to track it down and resolve…
Post #968477 20th Oct 2022 8:23pm
Caterham
/\ now to me that sounds like the problem Thumbs Up
its been working just fine again Confused
Procta - you're not the first to mention;
I think for the moment all I can do is so how things progress? Thumbs Up
Post #968725 23rd Oct 2022 12:02pm
Procta
Caterham, if you can get the car on live diagnostics, that should help. It should show you everything working and what isn't. Injector pressures etc. A good decent car tuner should be able to help you with that.
An old school tuner helped diagnose my dad's Jeep crank sensor. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #968768 24th Oct 2022 5:53am
Sounds fuelling related, possibly fuel pump or electrical connection maybe on main ground or live side.
Similar to how the VCV behaves when it fails on a Defender.
I would imagine you’d need live diagnostics and details of expected injector pressure parameters to take a look at that, personally I’d get it looked at and save yourself the headache unless you are skilled in the trade.
Even then these things can be difficult to diagnose as you can bet your life it’ll be fine when it’s taken anywhere. Laughing _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #968920 25th Oct 2022 9:41pm
Caterham
I will get a second opinion looking at the live data but I'm not really in a rush now as the problem seems to have passed.......I just know it'll come back when it's least welcome Crying or Very sad
I felt it was fuel related but based on very little.
will let you know what I find in due course. thank you. Thumbs Up
Post #968992 26th Oct 2022 6:26pm
