![]() | Home > In Car Electronics > Fuel pump electrical connector (Range Rover p38 pump) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
FYI - having to press the photos to get them to open (hosted on HTTP server not HTTPS).
The P38 docs I have show the pump to have a different connector to that. What's the pump part number? ![]() ![]() |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Looks a lot like a male Econoseal J housing
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Hmm good question on the part number. When I had the tank made, they (I think Safari Equip - ordered through Brendan at Overland 4x4) bought the pump themselves to make the tank fit around it. Subsequently I never got a retail box - Brendan did say it was a pump for a P38 though.
I will also look into a make Econoseal J housing, thanks Steve. Martin: thanks for the heads up on the images. I am not sure how to enable HTTPS capabilities on my hosted domain but I will look into it. 2005 Td5 90 XS 1989 V8 110 CSW |
Ah it might be Econoseal, I was looking at it wrong and thought it had an offset rib/key.
Turning my head through 90deg it might well be Econoseal. I’ve got some 4 way female plugs somewhere. ![]() ![]() |
Although this is a BMW engined diesel p38, I think the pump design looks similar as does the connector.
Timestamps 11:32 and 12:35 is where he is messing about with the plug. https://youtu.be/Jmp7guuJ6UA?t=689 2005 Td5 90 XS 1989 V8 110 CSW |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
An Econoseal III 070, 4-way female, fits this pump/sender unit -
https://www.polevolt.co.uk/acatalog/4w-Eco...tml#SID=57 ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Awesome thanks Paul - I'll get that ordered! 2005 Td5 90 XS
1989 V8 110 CSW |
