![]() | Home > Puma (Tdci) > LED Headlights |
billy56 Member Since: 05 Oct 2013 Location: Co Antrim Posts: 20 ![]() ![]() ![]() |
Cheers! Thanks for the photos, i see a set being ordered straight away 👍
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 ![]() ![]() ![]() |
Unfortunately my MOT tester failed the CRYSTAL LED HEADLIGHTS from SP 4x4 .
They failed on MOT test 4.1.2 c Not good. Maybe my mot tester was overly picky but he said they definitely do not conform to the UK MOT regulations on beam pattern. Any comments on this would be welcome?? "You are never to old to learn something new" |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18003 ![]() ![]() ![]() |
I think at this point I'd be contacting SP 4X4 since they appear to have sold you a defective product. Perhaps they've supplied a DOT version not an ECE version.
Good advice there from Custom Steve. Thank you. I've been back to SP 4x4 and they say they have sold thousands and have offered a refund black wolf. That doesn't really help much as I have to start from scratch. They were only £66 a pair so no great outlay so maybe look for something better.
They are marked with E9 which is the Spain test number, E11 is uk but E marking is all about eelectromagnetic compatibility not functional testing. Maybe worth pursuing with another garage or Halfords to get them alighned as a pre MOT job. "You are never to old to learn something new" |
They look like the generic eBay / Alibaba specials that have flooded the market in recent years. IMO at that price you're taking a bit of a risk. I had truck lites that passed an MOT with no issue, and again I had Wipac Crystals that I aligned against a barn wall that passed without a problem. |
Yes maybe lord haggis but most of these parts come from China anyway whatever price you pay. It will be good to hear from someone who has bought the same from SP 4x4 and got them through an MoT test. "You are never to old to learn something new"
It would be interesting to see what the beam pattern looks like if you park up 20 feet or so from a wall. It should be pretty obvious if it is drastically wrong.
This is how they are marked. If it helps anyone explain it.
![]() Click image to enlarge "You are never to old to learn something new" |
Those markings mean diddly squat on their own, and certainly don't mean the lights are legal.
The full compliance marking requires in addition; 1) Code for country which has done the approval (E + number in a circle, and E9 appears to be Spain) 2) The UNECE regulation number which is 43R 3) The actual approval number typically 4-6 digits. You will also find the manufacturers name on the glass. There is a large number of generic Chinesium knock-off lights with misleading and usually fraudulent markings on the market in the UK at present, and it seems as though you may have some. It's entirely possible that SP 4X4 has itself been hoodwinked. It's a shame that Leeds (Brendan) is no longer an active poster since this was very much his specialist subject. |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378 ![]() ![]() ![]() |
Completely agree. I was thinking of picking these up now they are in stock again at SP, but seeing the output would be really helpful . My mot man is reasonably relaxed in terms of markings/stamps etc, but I don't want them if the beam pattern is poor. |
I'm out of time for the wall experiment but a good friend has also bought and fitted a pair of these headlights and he is going to do the wall test and goto see his mate who is an MOT tester to get his opinion. The fact that they may be copies and do not carry all the markings that BlackWolf expects to see may not mean they do not meet the required MOT 4.2.1 beam pattern. My MOT test experience suggests they do not comply but I'd like that confirmed by others that have bought them. A sample of 1 is not good statistically.
SP 4x4 state they have sold thousands of them and have them on their own defenders. If that is the case there should be a lot of unhappy punters who bought them and failed there next MOT test. If they do turn out to be illegal then perhaps trading standards will be interested? "You are never to old to learn something new" |
To be legal the must have been approved, have the correct markings, and have a correct beam pattern. The MOT test only checks beam pattern so lights which pass are not necessarily legal. Lights which cannot pass the MOT test due to an unacceptable beam pattern (as opposed to alignment) cannot be legal whatever the markings purport to say.
It is entirely possible that whoever supplies SP 4x4 has supplied lights from different sources and the fact your lights are non-compliant does not necessarily mean all their lights have been. That being said "we've sold thousands and never had a problem" is the stock first response in these circumstances. |
Two other observations: firstly SP 4x4 doesn't say the lights are legal for road use in the UK, only that they are "E marked" which without elaboration is meaningless, and secondly those pictured on their website clearly have the required additional markings to the immediate right of the DOT SAE E* mark, which your lights do not appear to have.
![]() On face value it would appear that the ones they illustrate are probably approved, legal, and compliant but those they have supplied to you are not. As an aside, it's worth being mindful of the fact that ECE Regulation 48 Part 6.2.9. "Other requirements" says: "Dipped-beam headlamps with a light source or LED module(s) producing the principal dipped beam and having a total objective luminous flux which exceeds 2,000 lumen shall only be installed in conjunction with the installation of headlamp cleaning device(s) according to Regulation No. 45.” Since SP 4x4 advertise a 2300 lumen dip beam, to be legal it would be necessary to have headlamp washers fitted. This is probably the case for all LED replacement headlamps, but again is not an MoT test item. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21005 ![]() ![]() |
If they have an E mark for Spain, could that not mean they are approved for the LHD market and thus LHD beam pattern and not RHD and RHD beam pattern for U.K. market.
Or are the approvals just done in xx country whichever manufacturer chooses? Again anything DOT approved (USA) can be LHD based also which is the wrong beam pattern for us us on U.K. roads. I’m not sure what the E mark numbers are on mine. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
