![]() | Home > Td5 > TD5 Non runner |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Before you get too worried, go around and clean up all the earth points around the vehicle and make sure that is not the problem. You know how bad earths can upset electricals....
If that does nothing to help then the logging of topside faults is a good sign you need to find another eco. Perhaps it is an opportunity to upgrade to an NNN ecu as you should have an earlier MSB if original. |
| Super7 Member Since: 05 Feb 2014 Location: South Bucks. Posts: 136
Thanks, I will go around all the earth points and clean them all up
I forgot to mention I have connected the ECU earth directly to the battery The ECU is the NNN type so I guess it’s been replaced at some point '52 Series 1 80" '99 Caterham 7 |
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677
Try another ECU. For basic test any TD5 ECU is ussable.
Are you sure, you have not get any watter into the ECU? "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
Thanks, the ECU is completely dry inside
I’ve been struggling to find one for a reasonable price, that’s why I thought I’d get mine repaired, but then they told me they tested it and it was ok '52 Series 1 80" '99 Caterham 7 |
| Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128
Think this maybe the lArge capacitors in the ecu these are the usual culprits for a top switch error being generated sorry
Try to borrow any TD5 engine ECU, just for testing if engine runs. From Defender or Disco2 - any can run the engine for test. You need just learn the securitity code with Nanocom.
Top switch fail and others - possible internal ECU fault, but not 100%, I have seen this also, when there was bad connection between ECU and injectors. And faulty capacitors are possible, but not 100% reason for this fault. Injector open circuit fault is missing connection between ECU and injector. Look fot this first - check connectors, clean them and try to bend the internal pins on the female connectors a bit to make the a bit more tight. No need to replace them firts. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
| BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924
Topside Switch Failure usually means the ECU is dead, I’m afraid. It doesn’t need oil inside to die either.
As others have suggested, trying another ECU in the vehicle should be your next port of call. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Thanks all, I'll see if I can borrow one before I do anything else.
I just can't understand why the ECU was tested and found to have no faults. '99 TD5 Defender 90 '52 Series 1 80" '99 Caterham 7 |
The only reliable way to test the ECU is using it in car for at least one hour, to let the ECU heat up. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
| Dtes Member Since: 01 May 2022 Location: Staffordshire Posts: 10
A topside fault is a good indicator that the ecu is poorly.
Can you clear the codes and see if it comes back when trying to re start ? |
Yes, the fault codes come back after clearing
I’ve managed to find another ECU for a reasonable amount, plugged it in and the engine fired first time, happy days I’m going to keep this as a spare and get my original one repaired, as it’s the more desirable reprogrammable type. If anyone has any recommendations, I would appreciate it. It just goes to show, if you send your ECU away for testing and it comes back as working, it may still be knackered '52 Series 1 80" '99 Caterham 7 |
Fantastic.
