Home > Maintenance & Modifications > Legal LED reverse light bulbs
Page 2 of 3 <123>
LR90XS2011
farmer giles wrote:
darren - what wattage cree are you using?
(same question to lr90xs2011, too, please?)
sorry Im not sure Ive had it in for 2 years and e/bay record does not go back that far, simular result to Darren so expect its the same DEFENDER 90 TDCI XS,
Post #256899 7th Aug 2013 5:58am
farmer giles
thank you, both Thumbs Up Thumbs Up
Post #256965 7th Aug 2013 11:44am
BrickBox
Just to bump this thread.
Is it okay to fit an LED standard fitment style reverse bulb without any other modifications to relays/fuses etc? 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #967482 12th Oct 2022 8:14pm
It will work, if that's what you mean, and is mechanically and electrically fine.
If you mean legally, morally or aesthetically the question becomes harder. Laughing
Post #967491 12th Oct 2022 9:34pm
90 Dreamer
The only 'legal' issue is with LED replacement headlamp bulbs......
Do what you like with the rest
Post #967492 12th Oct 2022 9:37pm
BrickBox
Brilliant- thank you for clearing that up.
As you can tell from my recent electrical questions, it’s not my strong point..
It’s only a reverse light I want to change to LED and the fog. 2017 L494 Range Rover Sport SVR
Post #967493 12th Oct 2022 9:38pm
I'm not so sure about that, any type-approve light fitting is legal only with the type of light source with which it was type approved, however headlights are the only ones which are checked at the MOT test and which have made headlines recently.
That being said I don't think reversing lights have to be type approved and E marked (but I may be wrong) but it is certainly illegal to have a reversing light with an equivalent light output greater than a 21 Watt incandescent bulb.
It is incredibly unlikely that you would be stopped for it though.
Post #967496 12th Oct 2022 9:48pm
MartinK
Has anyone found a good solution here (other than a scenelight etc)? Reversing lights on Defenders are not great on a dull wet night reversing between two gateposts!!!
I have a "powerful LED" bulb in just now. It's better than standard but still not great... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #967504 13th Oct 2022 4:31am
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
This thread gives a few ideas (apologies if it's "only" the scenelight-type approach you're already aware of). I copied the approach of a spotlight attached to the number plate light fixture, and that is working well.
https://www.defender2.net/forum/post887048.html
Note that I also had a hi output LED bulb in the standard reverse light. And, my reverse switch went flaky, which I replaced. Not sure if that was coz it was overloaded - but, to be sure, have now put a much lower wattage LED bulb in the standard location. The spotlight provides more than enough light anyhow.
Post #967512 13th Oct 2022 6:47am
MartinK
Thanks skidrov - some godd ideas there!
My reverse light switch also went flaky BEFORE I put a LED bulb in! I decided to upgrade the LED at the same time as fitting the new switch. It's better but not good enough
I like the idea of not drilling more holes in my Defender as absolutely necessary, so using the number plate illumination pod is a great idea Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #967513 13th Oct 2022 7:19am
There are lots of options for physically mounting additional lighting on the rear of a Defender - loads of existing bolts and holes in the crossmember or the door hinges with a bit of ingenuity in the bracket department. The challenge is always routing the wiring, though. If mounting something higher up then in through the door rubber is a favourite, although it's never appealed to me, to be honest. Lower down at crossmember level comes with the possibility of going through or underneath it to the rear light cluster. The numberplate plinth is neat as you can drill a hole in the underside of the plastic plinth although you may need to enlarge the hole in the body that's behind it. Darren
Post #967519 13th Oct 2022 8:47am
MartinK
Solid info there thanks Darren
I was just looking at these https://www.denalishop.co.uk/drl-backup-li...mount.html
I've used Denali products before on my motorcycles and found them excellent quality...
Hmm... Feeling a project coming on Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #967526 13th Oct 2022 10:01am
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
I copied what another forum member had done. I mounted a cheap led light through the mount that holds the number plate light.
Easy to connect to the reversing light and then switched so I could use it as a work light.
Because the draw is minimal no relay required.
Post #967527 13th Oct 2022 10:33am
MartinK
Thanks tr90 - looks ideal Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #967528 13th Oct 2022 11:04am
Retroanaconda
The reversing light is a warning light to others and is not really meant to be a means of illuminating what’s behind you. In my opinion a high level light is best for that as it provides a good spread and will also double as a working light, very handy for hooking up trailers or loading the car in the dark etc.
Post #967639 14th Oct 2022 11:42am
Page 2 of 3 <123>
