![]() | Home > Technical > ATB Transfercase |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 350 ![]() ![]() ![]() |
Had my first test drive in the build last night and when manoeuvring it through the unit and out I noticed the inside rear wheel was hopping/ skipping.
Will this be down the nature of the torque biasing diff in the TC or do I have the diff locked without me knowing? 4.0 V8 Defender 90 My Instagram |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
was it stuck in transfer box diff lock? ATB should not cause this DEFENDER 90 TDCI XS,
Potentially then, whats the best way to check - lift the car off the ground and try and "hold" a wheel? 4.0 V8 Defender 90
My Instagram |
yes
1 apply hand brake 2 gearbox in neutral 3 jack just 1 front wheel so it is just clear of the ground 4 try to rotate the front wheel if it rotates the transfer box is not locked if it wont rotate more than a few degrees it is locked think that is right others should confirm DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Brilliant mate, I'll give this a go tonight
![]() My Instagram |
Dtes Member Since: 01 May 2022 Location: Staffordshire Posts: 10 ![]() ![]() |
Thats right |
![]() I hope everyone is well and your land rovers make you happy |
