Home > Puma (Tdci) > Oil leak to watch for
bob neville
Found oil dripping from the front of the sump pan yesterday. On investigation the oil was coming from near the top of the engine and running down to the sump pan.
It looked like it was from the brake vacuum pump but underneath and to the rear.
Took the vehicle in to the dealer this morning and it appears the seal/gasket on the high pressure fuel pump, located just behind and below the brake vacuum pump, is shot.
Going in on Monday to be fixed.
Bob
Post #37622 4th Aug 2010 1:29pm
BigRuss
So did you have a fuel or oil leak????
Post #37627 4th Aug 2010 3:54pm
bob neville
It's an oil leak. Apparently there is an O ring that seals the pump to something and it looks like that has gone.
Problem is it is very close to the brake vacuum pump that also has a tendancy to leak but it is more obvious when that happens.
Bob
Post #37633 4th Aug 2010 5:22pm
mse
You saying that - when my brake vac pump went it leaked in two ways A) Exactly as you describe and B) the Classic spray pattern.
I recall the mechanic at Macrae and Dick mentioned something about another seal aswell as the pump's seal...maybe they did the two...maybe not...i can tell you i was lucky if stratstone changed the gasket Evil or Very Mad Mike
Post #37644 4th Aug 2010 10:29pm
when I got "shiney" out on Monday I noticed a few drips of oil on the floor, checked underneath and it looks like there is coming out of a unit to the front of the oil filter on the nearside/right hand side (looking from front), then running down the engine mounts, onto the chassis etc. only a small amount, but does this mean I am joining the "vacume pump club"? -
It's 18 months old and has nearly 6,200 miles ... so it's about time something went wrong ...
Post #86690 30th Aug 2011 9:30pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I have changed the vacuum pump twice already - each time after c.a. 20 000 km.
The last one is supposed to be stronger - when leaks will need new gasket only. Janusz
www.yahodeville.com
Post #86752 31st Aug 2011 8:25am
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Mine had the same last month, new brake vacuum pump under warranty
Post #86769 31st Aug 2011 9:40am
I took shiney into the dealers yesterday and they confirmed it was vac pump seal - fitted a new one under warranty whilst inlooked at the evokes and rrs models.
Seems ok now
Would have been nice fir them to wipe the oil from the engine bay but I guess it's part of the oem anti corrosion system ?
Post #88390 10th Sep 2011 6:53am
Merlin
Marshall’s didn’t clean any oil off my one when they renewed the vacuum pump, not that that surprises me. Still we’ve now had the chassis oiled for free! What I want to know, is who is going to clean all the oil off my drive?
Merlin
Post #88429 10th Sep 2011 3:58pm
pom
Merlin
That's what cats are for, you will find their fur quite absorbent.
Pom
Post #88436 10th Sep 2011 5:16pm
Zagato
Laughing Twisted Evil
Post #88449 10th Sep 2011 7:19pm
Bill
Ireland 2008 Defender 90 Puma 2.4 XS CSW Java Black
Bob
Hay Bob,
Found a lot of oil blasted on to the heater matrix, & all around top of engine, up on to the under side of the bonnet, right side as you look from the front, it seems to be coming from around the belts. trying to put pics up. is this what you had?.
Very Worried!
<table><tr><td><img></td></tr><tr><td>October 28, 2011</td></tr></table> 08 Puma 90xs
BMW R1150R
KXF250
Keep On Truckin
Post #96729 28th Oct 2011 9:43am
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Had two done on mine under warranty - one in a similar sounding place (near crank pulleys), the other to the rear of the engine - two gaskets replaced. THEN the brake vacuum pump went too! Also replaced.
I think our 110 is now about 15% brand new! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #96732 28th Oct 2011 10:09am
bob neville
Bill
Not the same as my problem, yours sounds like the brake vac pump.
Mine was not spraying oil around it was leaking from the fuel pressure pump gasket that is next to the vac pump and running down onto the sump pan.
When the vac pump seal goes it sprays oil all over the n/s of the engine bay.
Bob
Post #96755 28th Oct 2011 12:12pm
bob neville
Bill
Click on the picture links in the thread below Thumbs Up
http://www.defender2.net/forum/topic3182.h...ake+vacuum
Bob
Post #96757 28th Oct 2011 12:16pm
