Home > Technical > Vibration
90roy
Vibration
Hi guys,
I'm getting a vibration from the front end, through the steering rack and vibrating the whole car. It only happens under power between 45 and 55mph.
Any thoughts on what it could be?
Thanks,
Roy 300tdi 90 1996.
Post #967122 8th Oct 2022 9:52pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Possible wheel ballance issue. Try changing the front wheels to the back and take for another run and see if anything changes.
Post #967123 8th Oct 2022 10:47pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Also when the wheels are off check to see if there is any obvious sign of a balance weight fallen off. If they are stuck on sometimes you’ll see the sticky residue where it was. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #967127 9th Oct 2022 6:35am
markb110
Hi 90roy
I had the same recently and had it fixed this week.
The Swivel preload was shot and also needs a new bearing kit.
Problem solved.
It was also a good excuse to upgrade to the Gwyn Lewis drop arm kit and sumo bars Whistle
Post #967130 9th Oct 2022 7:20am
kenzle8a
Panhard rod bushes would be my starting point. I had a similar shake and did them before i attempted the swivels.
I used the superpro kit from gywn lewis
Post #967136 9th Oct 2022 8:07am
90roy
Thanks for reply chaps.
I forgot to say I have had new tyres and balancing done on the front , it got slightly better but still is there.
I was thinking bearing or front prop uj may be at fault but for both I can't understand why it only does it at that they speed, not all the time.
In relation to swivel preload and panhard bushes, how do i Check this?
Thanks,
Roy 300tdi 90 1996.
Post #967144 9th Oct 2022 10:05am
markb110
Roy
I let my independent deal with it.
In a nut shell the front needs jacking up, wheels off, disconnect every thing attached to the front hub, use a fishing weight to make a steady pull on the hub to measure the resistance.
Then you need various shims and in my case a bearing kit.
It’s a lot of faff for me to do due to lack of space and not knowing which shims to buy in advance.
Then you to check all track rod ends and replace in necessary or preventative and then do the tracking or arrange to take it to somewhere to be done.
It was easier to drop the 90 off and collect it knowing everything was done and ready for the coming winter.
And yes I did get the tyres balanced first as being the cheaper option and had replaced the Panhard bushes.
Post #967146 9th Oct 2022 10:23am
DSC-off
Every vibration has a frequency, Harmonic Vibration is when frequencies coincide and the effect is multiplied (made worse in this case).
Coincidentally, my front tyres make a slight rumble noise around 48 mph, but this may not have the same cause as your issue. At 96mph, I'd expect the noise to come back again Laughing
Post #967147 9th Oct 2022 10:40am
kenzle8a
Thanks,
Roy
You can see it moving if the bushes are worn (the panhard rod) if someone else turns the wheel with the vehicle on the ground. I just swapped mine out for the low cost of it and as far as I could see it hadn't been done for a while.
The props vibrations are different (in my exp), I found you a lot more noise combined with the vibration. I could hear my UJ's complaining.
Post #967148 9th Oct 2022 11:16am
Dinnu
Good luck reaching the 2nd harmonic Laughing 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967153 9th Oct 2022 12:09pm
Dtes
1984 Defender 90 Td5 HT Firenze Red
Swivel pin pre loads
Panhard rod bushes
Steering damper & propshaft are the things i’d be checking
Post #967828 16th Oct 2022 12:08pm
Puddings 3112
Had a similar vibration on my TD5 between 35 and 45 despite balancing the KM3s. Just had a front end rebuild and the bushes were completly shot (as were several other rotating/moving parts listed below). All replaced and on the long test run yesterday, the vibration has gone.
List of replacement parts that might have contributed include:
bushes
front bearings
Discs and pads
Front CVs (cause of the job)
dampers
Post #967945 16th Oct 2022 9:18pm
90roy
Thanks all.
I'm going to give this a good look at this week.
What's best way to check for a dodgy wheel bearing?
And where can I get the shims needed to set end float on the half shaft?
TIA,
Roy 300tdi 90 1996.
Post #969440 30th Oct 2022 5:21pm
Dinnu
When you jack up the wheel, check for play by trying to rock the wheel in every direction. Then ask an assistant to press and hold the brake. If all play goes away with the brakes on, then you have play in the wheel bearings. If play is still there with the brakes on, especially when you rock the wheel at 12 and 6 o clock, then you have play in the swivel bearings (king pin). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #969458 30th Oct 2022 6:27pm
90roy
Many thanks. I shall take a look at it this week. 300tdi 90 1996.
Post #969473 30th Oct 2022 7:24pm
