Home > Maintenance & Modifications > Blue/Green fluid at gearbox/transfer box joint?
Page 1 of 3 123>
Co1
Developed a fluid leak as per above. The fluid feels oily, doesn’t smell in any way burnt or over heated. Appears green in colour! Any thoughts?! I can confirm that the transfer box oil isn’t green. I have never done the gearbox oil though; would that be green?
Col
Post #967054 8th Oct 2022 9:36am
Dinnu
The Millers oil I used that went into my gearbox was normal golden colour. The oil that came out was just a darker shade of gold.
Could it be diesel? There are 2 pipes clipped to the underside of the seat box that cross from the fuel filter to the fuel cooler. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967057 8th Oct 2022 10:32am
Co1
Cheers Dinnu. It’s thicker than diesel, viscosity wise it feels almost thicker than engine oil as well.
Post #967058 8th Oct 2022 10:50am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Could be diesel, but you would smell it and it looks too green. Looks a lot like antifreeze/coolant to me but not sure how it would be getting that far back? How is the coolant level?
Even if coolant was leaking from the back of the head/headgasket it is still some way for it to get to the back of the gearbox, unless it is tracking along a wire or cable.
Post #967059 8th Oct 2022 10:56am
Co1
Yeah, I was thinking coolant or similar as well but again it feels a bit too thick. Might be wrong though, I’ll check what colour it is in the reservoir.
Post #967060 8th Oct 2022 11:01am
Ianh
If coolant has not been changed from factory it should be orange, if changed it should be orange or red if correct fluid used.
Worth noting that some corrosion on non ferrous metals can turn fluids a green or blue green colour if the fluid is settled on it for a while.
So like others I suspect that green ( looks more blue in pic) fluid has come from above and may not have started green but mixed with some corrosion has turned that colour and then run off.
Ps in your pic it does look like it’s come from above as at the bottom of that flanged bolt it looks like some fluid of the same colour is there as well.
Post #967061 8th Oct 2022 11:19am
Co1
Coolant is red. Rolling Eyes
Post #967062 8th Oct 2022 11:19am
Ianh
Have you lost any coolant? Your EGR cooler and associated coolant pipes are at the very back of the engine.
Post #967064 8th Oct 2022 11:50am
Co1
Have had a good look around and can’t see anything coming from above. As I reach around the gearbox and transfer box there is no dampness, only dust so it doesn’t look to be coming from above. There is evidence inside the tell tale at this junction, although that could just be capillary action is suppose.
Thoughts? Transfer box input seal or gearbox output seal?
Col
Post #967065 8th Oct 2022 11:52am
Dinnu
Could drain a few drips of oil out of the gearbox or transfer case to see that the oil is not green there? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967066 8th Oct 2022 12:48pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Probably one of the two. Try a smell test. Remove the gearbox and transfer case fill plugs and see which one the leaking fluid smells like, they should be different and have distinctive odours.
Post #967068 8th Oct 2022 12:56pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I've used oil additives that were sufficiently dark to stain a whole gearbox worth of golden-coloured oil a different colour. I'd go for Dinnu's suggestion: it's quick and easy to dip into the gearbox and colour match your leak with the contents.
Post #967074 8th Oct 2022 1:55pm
Co1
Drained a bit off the gearbox, it looks like normal oil but has the slightest hint of green in it! I’ve degrease and cleaned off the whole area so I’ll give it a week and check again. Just weighing up if I have to split the transfer box off to replace a seal, should I re fit with a Winchester Gears ATB LT230?! Will make it a bloody expensive oil seal change!!
Post #967075 8th Oct 2022 2:01pm
Dinnu
When I got my Puma I had a bad leak from the adaptor housing. It had the ashcroft adapter shaft, but the shaft cover was cross threaded and the O rings on the ashcroft adapter shaft did not seal properly. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967082 8th Oct 2022 3:01pm
Co1
I’m heading towards 95k miles, so if it is an oil seal I suppose it’s done pretty well compared with some of the horror stories out there.
Post #967086 8th Oct 2022 3:45pm
Page 1 of 3 123>
