Home > Td5 > Oil leak identification
Reynard
Good morning,
Can anyone please identify my oil leak, I'm guessing gear box gasket? It is due in for a service at the end of the month. Is this a big job to do these days? Thanks.
Post #966403 2nd Oct 2022 7:59am
landy andy
It could be a few things, but I think you will find that is an engine oil leak.
It looks to me that it is coming from around the bell housing so is above the gearbox. Rear camshaft oil seal, rocker box gasket, or a leaking fuel pressure regulator would be my checking points.
Post #966413 2nd Oct 2022 10:15am
markb110
Hi, I had a similar oil leak which was traced back to the half moon on the rocker cover gasket.
At least a cheap fix.
Post #966416 2nd Oct 2022 10:47am
Reynard
Thanks guys, it's the only leak I have on it for now, hopefully the chaps at the garage during the service will be able to trace it back. Thumbs Up
Post #966417 2nd Oct 2022 10:54am
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
I spent several days looking for the start of the leak. Took the lower engine cover off, which is an event by itself, cleaned everything I could reach with degreaser. Took it out for a drive to get the oil flowing and left a long trail of diesel behind me as I must have knocked the pipe loose on the fuel cooler.
Now with everything covered in diesel had to clean it again.
Finally found the leak in the centrifugal oil filter housing. Replaced the o-ring and sealed it tight and leak has gone.
Still need to replace lower engine cover. Need to find an easier way to do it.
Steering box leak solved with a bit of brake fluid in the mix.
A good couple of days working on the car.
Post #966439 2nd Oct 2022 5:42pm
Jhollow
Canada
How does a little brake fluid in the mix fix a steering box leak? Thanks 2006 90 originally registered in Italy
Post #966456 2nd Oct 2022 10:01pm
Tr90
I discovered the tip on this site.
Only put a small amount in. I think I used two cap fulls I believe it softens the rubber seals.
Certainly has stopped the leak
Post #966467 3rd Oct 2022 7:58am
Depending on the type of brake fluid I could believe that it makes the seals swell, which might stop a leak. My understanding is that the when seals swell they are in the first stage of breaking down, but I may be wrong.
I can say with some confidence however that it is something I won't be doing unless much more supporting evidence that it is a good practice comes to light.
Post #966477 3rd Oct 2022 9:53am
Tr90
I don’t suggest that it’s good practice. But if it means that I can get a bit more use out of the existing part whilst I gather the funds to purchase a reconditioned one then it works for me.
Post #966482 3rd Oct 2022 10:35am
