Home > Technical > Wipac led lights
Pacman
United States 1985 Defender 90 2.5 n/a Diesel CSW Bonatti Grey
Wipac led lights
I replaced oem lites with Wipac led ….they work great…blinkers blink…stoplights work…. Running lights work, ….but my tach does not work it will jump when when the key is turned and my Kenwood 7706s will not turn on…..did I miss doing something??? ……help!!!
Post #966393 1st Oct 2022 10:13pm
Screbble
Obviously there’s no circuit connection between the headlamps and the tach, audio etc. so you must have inadvertently disconnected and/or moved something in the process of fitting. That said, you wouldn’t necessarily have been working behind the dashboard to fit the headlamps so I can only ‘guess’ you’ve interfered with an earth?
Are you sure it is the headlamp fitting that has caused the issue as you may be chasing a red herring?
Post #966401 2nd Oct 2022 7:27am
Pacman
Thanks for the reply
So I just removed and replaced all the lights. (I Did not do side repeaters or headlamps) I was very slow doing this I checked all the ends to make sure I was hooking the wires up it was pretty easy 6 lights are 2 wire and brake and running lights are 3 wire x2….I had been turning ignition on and off all day and when I took it out for a drive low and behold kenwood head unit and tach was working…..the only other item I messed with was the flasher that was plug and play as you know……I’m going to let it go and see what happens or the next few days. Thanks again for replying
Chris
Post #966423 2nd Oct 2022 11:37am
Pacman
Post #966424 2nd Oct 2022 11:38am
