![]() | Home > Off Topic > Got a bill today... |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Was up today with the independent I use getting the drop arm on the Defender attended to. Nothing major. The rubber boot had split so they took the boot from a repair kit and fitted that and I took the rest of the kit home. Anyway when I was settling up the bill he told me that he had the bill for work done on the series 111 made up, so I paid that too. The work on the series 111 was done in...2020 1982 88" 2.25 diesel
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1323
Guess he doesn't need the money and is doing the work as a hobby
Full time outfit, just easy going!! 1982 88" 2.25 diesel
| ak615 Member Since: 22 Aug 2018 Location: essex Posts: 194 |
Did you say you would settle up later ?
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2703
Good job you paid as he would have called the police as it was an ‘Old Bill’…….
Have you got a part number? 1982 88" 2.25 diesel
| The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303
Yes you can : http://www.rhinorubber.co.uk/LBJC.html
Avalable from Motor Parts Direct : https://www.mpdonline.co.uk/ it's a part that is not lised on the website, but if you go instore and ask / describe they should have stock or can get it. Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Thank you, much appreciated
