Home > For Sale & Wanted > Wanted: Safari Equip Bumperettes |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
I'm looking for a set of bumperettes for the rear of my Puma 110.
The Safari Equip ones look like the best ones for me. Apparently (just called them) the design is changed slightly between the TD5 and the Puma, so it's Puma-specific ones I need. Anyone got any for sale (or know where I can get a "deal")? Don't mind a bit of repainting if needed If anyone else is interested, we could approach Safari Equip for a group buy? Maybe one of the "dealers" (Sonic, Brendan) can get them for us if there's enough interest for a group buy? Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
27th Oct 2011 2:07pm |
Martin,
if you have a mantec spare wheel carrier, make sure they still fit |
27th Oct 2011 6:46pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2877 |
Why not just buy a new pair
27th Oct 2011 8:09pm |
Yep, £127 + carriage + vat, so around £170 all in. Probably some of the most expensive bumperettes out there, but they are nice (as Zag confirms)! I have spent a lot on the Defender since buying only 1 month ago! Noisekiller, Dinitrol, tow bar, Nakatanenga glove box, side steps, mats, TGE panel kit, full oil change, roof rack...everything I "need" when buying the new Defender.... (I would add it up but the cost would scare me! Must be at least £1000 over and above the cost of the actual Defender ). Was trying to keep the costs under control a bit....maybe I will ask SWMBO to get me them for Christmas Paddock & Devon4x4 (Bearmach ones I think) do similar stuff for around £60 +vat+delivery... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
28th Oct 2011 8:24am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Yes the Safari Equip ones are a lot more then other makes. Some people say you get what you pay for.
I have seen some of these cheap bumperettes. A guy wandered on to our stand at Peterborough with a set of them. A quick comparison showed that they were made from steel about half the thickness of the Safari ones and sat closer to the rear cross member. To fit a swing away wheel carrier you have to carve a big lump out of them which weakens a weak bumperette even more. I pointed this out and got told that they were only for show! Will try and post some photos up in next couple of days. It is your money, your choice. Please ensure that any after market kit that you buy is compatible with anything else you might want to buy in the future. Brendan |
28th Oct 2011 6:30pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Not by a long way Look at the Equipe ones they are double that Click image to enlarge |
28th Oct 2011 8:08pm |
It's the Equip ones I want! I guess I'll just get them...I'll ask SWMBO to get them for me for Christmas £127.50 + VAT + Carriage - Unless a 2nd hand pair come up first Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
28th Oct 2011 9:39pm |
Equipe not Safari Equip, they are Italian and prefer pasta than chips and gravy [/u]
28th Oct 2011 10:01pm |
The cheaper ones fit closer into the rear cross member and to fit a swingaway wheel carrier you have to carve a chunk out like this.
Click image to enlarge Step off a rock and you can see the battle scars from a weaken already weak rear bumperette Click image to enlarge A wise man learns from someone else's mistakes. A sensible man learns from his own mistakes. A fool never learns from his mistakes! Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Nov 2011 5:41pm |
Nice one Brendan.
For me it was transparent, I had a mantec spare wheel carrier fitted by a local indy and they shortened the bumperette and re-fitted the chequer plate, it was not until i removed them from my old 110, I found out they'd chopped them down. (they need a paint too) Click image to enlarge |
1st Nov 2011 7:27pm |
jayaway44 Member Since: 04 Nov 2011 Location: Edinburgh Posts: 111 |
Can you please tell me if any bumperettes will fit without needing modified as I have a mantec wheel carrier fitted.
Thanks 2.2 2012 110 utility Orkney Grey Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
8th May 2012 9:02am |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 71 |
I can't find anyone who sells these - any deas where I can find a set, or failing that Terrafirma for my 110 Puma. Equipe are my preference....
Thanks, H
2nd Sep 2013 9:59pm |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
First four sell them to fit with a wheel carrier and are great quality.
2nd Sep 2013 10:32pm |
Can't see your point from this photo? The bumperette doesn't appear to have any bends or kinks in it so not sure how the damage to the wing happened or is related. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
3rd Sep 2013 9:27am |
