Home > Td5 > Aftermarket AC
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
Aftermarket AC
I'm looking into the possibility for adding AC to our td5 110 but only end up with the approx. 5k setup from LR. is there any alternative that is viable for the builds? google somehow does not give me any other hits ... Td5 110 Station
Post #966041 27th Sep 2022 7:49am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Post #966045 27th Sep 2022 8:27am
Penfold_6290
Or this, I just saw you are in Switzerland, your 110 is perhaps a left hooker??
https://www.lrparts.net/da2342l-land-rover...tment.html
Give it a couple of days for the currency to be further devalued and it'll get cheaper and cheaper!
Post #966046 27th Sep 2022 8:32am
geobloke
IIRC all of the aftermarket TD5 AC kits are made by CoolAir Logan: https://www.coolairlogan.co.uk/land-rover-air-con
I have this kit on Miffy and it works well and looks OE. One benefit is that it will fit behind a standard Defender non-AC grill if you want to retain the flat front end.
Post #966071 27th Sep 2022 12:32pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
As above check out coolair (OEM supplier) and also look at Ministry of defender kits…
https://ministryofdefender.co.uk/buy-puma-...category=0
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #966099 27th Sep 2022 6:59pm
A.Rubio
Spain
Post #966256 29th Sep 2022 4:18pm
