|  | Home > Puma (Tdci) > Ureka ! |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347      |
 well that might just be a bit premature but.......
 (firstly thanks to whoever mentioned it on here somewhere - I've forgot and my search skills leave alot to be desired). so 2011 MY 110XS and I've had doubts from the day I bought as to whether things were right or wrong. within 50 yrds of leaving the forecourt it kangarooed and then nothing. it happend once may twice more then its not happened since. however i have had concered over it running smooth and then not smooth at various speeds and for varying amounts of time. most annoying being crusing along the motorway at my favourite speed - 33mpg average.....I mean about 55mph and there's an almost constant resonating. checked and checked again the heat shield. more recently I sounded like it was related to the air intake, so I'm thinking could it be the MAF sensor - would / could this change the amount of air intake? THEN someone on here mentioned it the airbox lid fitted properly !!!!! no it wasn't clips were on but the back of the lid wasn't tucked in properly - now it is and this appears to have made a difference. the jury is out until tomorrow when I'm off to Swansea and back so I'll let you know how I get on. So all I can say for the fews seconds it takes to check - check it.  | ||
|  27th Oct 2011 9:19am |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813    | Glad it worked. Mine was not refitted correctly after a service and it lead to a very noisey engine. Should be checked as standard after a service. 1982 88" 2.25 diesel
 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai | ||
|  27th Oct 2011 5:30pm |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682      | Thanks for posting - I'll check mine this weekend.    Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) | ||
|  27th Oct 2011 5:33pm |
| twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655      | This happened to my old Toyota - made a noise under power like the exhaust was blowing. Fortunately spotted the real cause before I bought a whole new exhaust! | ||
|  27th Oct 2011 6:35pm |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347      | Swansea got cancelled but from the little use it got last night I'm convinced its job done !!!
 amazing how much of a difference this can make (especially when it appeared at a glance to be fine).  | ||
|  28th Oct 2011 1:58pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
