![]() | Home > Td5 > Read door - glass fitting |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
Hey I’ve just done mine and used 3M body caulk to fit the window and it worked great. I believe they were originally put in with dum dum but that’s no longer available. Only downside of the 3M stuff is it’s grey, but once you’ve got it tidied up you don’t see it.
I used this guide. I found instead of doing the ruler trick he did is make sure you have the caulk right on the edges so when you push the window in it squeezes out. I then used a plastic scraper thing to trim the excess off neatly. I was very happy with how it came out and it never sets so if you need to remove the window or anything you can do so with no horrible sealant to scrape off. I got the bossy caulk from woolies trim and 2 packs of 10 strips did the inside and out ok. I just stretched the strips on the inside so they were longer and thinner as the inside doesn’t need much. Hope this helps! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Cheers for the video. I will take a look.
With the kit I got for fixing the window in came with the ally strips, screws and a length of rubber. I will have to drill new holes for the screws as I am using a new door. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
This stuff.
https://www.woolies-trim.co.uk/p-1979-body-caulking-10-strips 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Yeah that’s the one
