Home > Puma (Tdci) > Defender 110 power issues and temp overheating |
Yesjus Member Since: 19 Sep 2022 Location: Surrey Posts: 78 |
To also add, to help with the over heating I turned the heater on and I dont know how well they work but the lower heater was burning my leg!! Maybe a radiator issue??
21st Sep 2022 4:12pm |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 374 |
Are the spikes in temperature immediate or take a few minutes?
If immediate then this would suggest the issue is electrical (sensor, ecu, or the wiring in-between) rather than a physical issue with the cooling system. |
21st Sep 2022 4:25pm |
The coolant level remains normal. However I have a OBD scanner and it’s showing no faults!
Also after inspecting the underneath i am noticing a lot of brown water/oily residue under the engine but no obvious leaks/drips. Is this normal? (Added pictures below) Last edited by Yesjus on 21st Sep 2022 5:55pm. Edited 3 times in total |
21st Sep 2022 4:30pm |
I would say gradually rising at a fast pace (20 seconds or so) instead of immediate spike so don’t know if this would point to an electrical problem Last edited by Yesjus on 21st Sep 2022 5:54pm. Edited 3 times in total |
21st Sep 2022 4:35pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
I can't help with the issue but hopefully the knowledgeable will be along shortly.
But welcome to Defender ownership and D2N James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
21st Sep 2022 4:46pm |
Just to add, don’t know if relevant but I finally got home and it died again on me as just pulling up.
I’ve let cool and went to move onto drive. On start up it bellowed white smoke form the exhaust…I applied some throttle and the white smoke turned to a small bit of black smoke before clearing. If I rev hard it will still produce black smoke. Hope this helps. Thanks again guys 👍 |
21st Sep 2022 5:24pm |
Really need some help here guys with suggestions.
It’s been in the garage now for nearly 2 weeks. Mechanic can’t find anything!!? He’s also done some road tests and it hasn’t done the problem with him?? He’s done electrical checks, head gasket checks etc and no results that indicate problems. It’s being dropped back tonight…any thoughts on what it could of been and maybe self corrected or anything my guy might of missed? Thanks |
3rd Oct 2022 4:50pm |
All I can suggest is use the search facility here to look at other threads.
A few to start:- https://www.defender2.net/forum/topic21349...power+loss https://www.defender2.net/forum/topic67703...power+loss or search results for you to wade through:- https://www.defender2.net/forum/search.php...rch_time=0 James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
3rd Oct 2022 5:02pm |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 323 |
If you drive it up to temp, do your coolant hoses remain rock hard after after the engine has cooled down?
Have you noticed if this happens or starts to happen only when you're going up hill in a high gear? |
3rd Oct 2022 5:30pm |
I’ll check when I next pick it up. Assuming if it’s hard it could be an internal blockage?
4th Oct 2022 4:30pm |
Thanks for the links. I have scrolled through many a thread and there is lots of potential things it could be! It doesn’t help that my mechanic (a Land Rover specialist) can’t find anything at all?? I guess my question is does any one have any idea or can take a guess at what it may of been that has corrected its self?? That way I might be able to drive it and convince myself it’s all okt 😫 |
4th Oct 2022 4:34pm |
When this happened to mine, it turned out to be the head gasket. I also changed a lot of parts too! The reason I didn’t think it was the head gasket at first was because when I did a the reld test for gasses in the coolant, it came back negative. |
4th Oct 2022 5:37pm |
The mechanic has checked the block etc and done tests but your saying it could still be head gasket then?
If it was head gasket could it appear to be self corrected? ( it done it 3 drives in a row?) My guy has had it and it hasn’t done it at all?? Don’t know if relevant but Just before doing this it sat for 2 weeks, it was when we had that really heavy rain? Maybe water got in somewhere and has since dried out?? Maybe dirty diesel sat in tank 🤞🏻🤞🏻 |
4th Oct 2022 6:54pm |
I only mentioned the head gasket as my car was up and down for a while. It became predictable when it was going to go into limp mode but it took a while before that happened. It was always going up hill in 6th gear that would trigger it. If i didnt change down before it got into the red then it would become unresponsive to throttle for about 10 - 15 seconds.
It might not be the same for you but if you know the signs then you can look out for it. When it started it happened out of the blue and it was only once in a while. I had another temp gauge issue on start up but I fixed that by cleaning the Cylinder Head Temp (CHT) contacts with contact cleaner. Cheap fix but a pain to diagnose. If you have a scanner that can give you a live temp reading then that might be useful to see. Under normal conditions mine doesnt go over 94c with it usually being in the 89c-92c range. |
5th Oct 2022 7:37pm |
