![]() | Home > Faults & Fixes (L663) > Noisy door seals |
Ritson Member Since: 11 Apr 2021 Location: France Posts: 202 ![]() ![]() |
My 22 SE has suffered from the common problem (or so it seems) of the door seals creaking & crackling. I've tried the recommended silicon lubricants etc but all these seem to last only a few weeks before the noise resumes.
Does anyone with a MY23 have the same issues? Just wondering if LR have resolved this issue with different seals in later production runs. If so I'll see if my dealer can get them changed under warranty. Cheers all Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1306 ![]() ![]() |
'Harrys Farm' 90 suffered that also.
Bumpy Member Since: 07 Sep 2016 Location: Hampshire Posts: 17 ![]() ![]() ![]() |
My 21 plate 110 also suffers with this. I am arguing with LR about it.
To the best of my knowledge there is no know fix. Odd how some cars suffer and not others!? |
hezor Member Since: 01 Feb 2021 Location: Nurmijärvi Posts: 53 ![]() ![]() |
My 22MY P400e had this creaking last spring and I sprayed every door seal with Würth Rubber Care (which does not include silicone, as silicone is asking for trouble). No creaking since. Let's see if and when that returns. 22MY Defender 110 P400e SE w/ Off-Road Pack, Driver Assist Pack, Cold Climate Pack, Comfort & Convenience Pack + ClearSight Rear-View Mirror & 11.4" Infotainment Screen
I can't find that for sale in France unfortunately Current: MY22 P400e SE
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
Gummi Pflege is similar stuff if you can find that.
I have some Gummy Pflege Stift on the way courtesy of Amazon! Current: MY22 P400e SE
County V8 Member Since: 07 Jun 2021 Location: UK Posts: 151 ![]() ![]() |
+ 1 for the
Gummi Pflege also stops doors sticking in winter |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
my 23MY also does it, and its only got around 400kms, so will use silicon spray as I did on the 20MY I had. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
Gravygraham Member Since: 15 Mar 2017 Location: East Kent Posts: 187 ![]() ![]() ![]() |
What don’t you like about using silicone? |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3424 ![]() ![]() |
Hmmm no creaky door seals on my MY2022 90 Commercial.
There was a creaking noise from the dashboard area but it turned out to be my knees. |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
On early cars there was an issue with noises coming from the door seals - in particular from the top right and left corner at the door jam. Turned out that the radiused rubber “flap” was loose and tapping on the glass. On my 110 it was on all the doors except the tailgate. Cure was to drop the window and peel back the rubber where you would find the remains of a double sided sticky patch that had dried out and become detached- a dab of automotive sealant on the rubber and sticking it back to the metal of the door frame cured it and I haven’t had a noise from there in the last nearly 3 years. There was a video about this on YouTube posted by a member here. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
thank you Tim. Could you please post a picture of where you mean. Sorry if I am being daft but not sure I understand where it is and have searched for the video with no success.
Thank you "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
Bruce - I’ve since changed my 110 to a 90 but have found this in my gallery
![]() Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
