![]() | Home > Puma (Tdci) > Brake hose from ABS modulator |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
The middle one has totally different end - it has opposite cone. For sealing is the inner part, not the outer cone part. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
olivers Member Since: 19 Jan 2012 Location: Southern Scotland Posts: 115 ![]() ![]() |
Hm... if that's true then the problem is bigger than I thought. Any clue which of the options in the Furore shop (https://furoreproducts.co.uk/custom-brake-hose) would give me the correct result? Or even the larger size connector in the photo? |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Cannot help with your problem, except to say that there are different flares on brake pipes.
See this thread for further information Home > Technical > Overthinking Brake Pipes Hope this points you in the right direction until someone can help with the specifics. |
No question! However, in various videos I saw about brake pipes on Land Rovers, I never saw a flange that was not like mine. Never saw different size unions either! Strange thing altogether... I think I saw the thread before which you're pointing out -- I'll have another look. Meanwhile very interested in case someone has the "goods" on this topic, i.e. what the correct union types are called or where to find them. |
I've now had a reply from Furore. Two points:
1. The 10mm union should fit just fine in places where the pipe flange in the photo was previously used. Apparently this is a "dual seated" union, which is why it has both the concave and the convex section, providing it with broader compatibility with other parts. I asked about this specifically because I wanted to make sure I could use the hose I already installed. 2. They don't have a 12mm union type, but they should be available here: https://auto.helperformance.com/custom-car-braided-brake-lines -- that's the supplier used by Furore, and they should have hoses that are exactly the same (color, etc) but a broader choice of union types. I'll go check availability now and hopefully find what I need. Thanks for your help, everybody! |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
My 2010 defender has all DIN flares on as original, I recently replaced all my brake lines due to a couple of failures and close calls.
I used the DIN flare on the all new joints my thought was if it’s good enough for Land Rover it’s good enough for me! Didn’t have any issues. I bought a kit from a local Euro parts which had both the sizes of unions in 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
So did you make your own hoses with these unions? Do you have links for the parts you used?
i didn't use hoses apart from the stainless ones at the calliper, i used copper kunifer/cunifer pipe which is a better choice due to its high wall strength for bending. i also bought a chip flare tool from eBay which was faultless.
it was a but tricky but because i could flare pipe i could put it in sections, obviously body off at the factory would have been very easy. 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Fair enough, I see.
Well I started from the position that it's impossible to put in new brake pipes without dismantling much of the engine bay. Using segments occurred to me but that does seem like a lot of extra built-in fault points and of course many places would still be extremely hard to reach given the rigidity of the pipes. Using hoses instead apparently doesn't have any disadvantages -- several previous conversations had about this -- and it's obviously very much easier to do. Turns out the one unexpectedly problematic step is to get hold of the correct union connectors -- who knew. But this will hopefully be sorted out soon and then I think this will be money well spent to avoid the hassle of pipe connections. |
