Home > Maintenance & Modifications > Brake caliper paint
Page 2 of 4 <1234>
Screbble
I do like IPA Thumbs Up
Post #965373 18th Sep 2022 10:19am
Screbble wrote:
Absolutely right Blackwolf!
At times like this I ask myself “what would Kahn do?”
And then I do the opposite.
(Except for blingy red calipers which I do like because of other red themes going on on my truck…)
Anthracite it is then Blackwolf Thumbs Up
Don’t forget to book the Dyno… Rolling with laughter
I like that philosophy! Rolling with laughter
I have decided to go with a "graphite" colour VHT spray which I'll probably then high-gloss lacquer (again VHT of course) since gloss should resist sort better.
If it doesn't work out I'll know not to do it next time. Very Happy
Post #965375 18th Sep 2022 10:27am
The Zee
I hope you are refering to Indian Pale Ale!
Weirdly propan-2-ol (Isopropyl Alcohol / IPA) is not a great degreaser it is too polar and has a poor affinity for grease and oil based contaminants, it does not really like to dissolve them. A better solvent would be something like hexane, methyl benzene (toluene) or di-methyl benzene (xylene) all of theses are less polar and dissolve oils and grease really well.
My chemistry tutor always reminded me that “like dissolves like” so yes propan-2-ol can be used but in conjunction with a wiping with brake cleaner/carb cleaner/cellulose thinners. Zaid-M
www.DefencePhotos.com
Post #965666 21st Sep 2022 9:20pm
Screbble
Yes India Pale Ale 🍺 Thumbs Up
I don’t use it for cleaning or degreasing though…
I may treat myself to some s/s bleed nipples so thanks for the link Thumbs Up
Post #965673 21st Sep 2022 10:16pm
LR Nuts
I know I am going to be shouted down here ........ and I nearly didn't post this information......
You need to inform your insurance company if you paint the callipers other than the original color they came.
Google it .... it's a thing ....
I'm ready for the onslaught .................................
Post #965690 22nd Sep 2022 9:48am
No, you're right, and the reason is because the colour the calipers are painted says a great deal about the mentality of the driver. Brightly-coloured calipers are likely to increase your premiums. I am hoping that a dull, boring, sedate, sensible graphite grey colour will reduce mine! Very Happy
Fat chance, of course. Sad
Post #965693 22nd Sep 2022 10:50am
Grenadier
Blackwolf: ‘ I am in the process of overhauling a set of calipers which I removed some time ago from my Defender. They've been stored for some time since I removed them and were pretty scabby when I started. ’
How have you been stopping? Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #965754 23rd Sep 2022 6:49am
Screbble
My wife would agree with you - I must be having a mid-life crisis.
(I did have XR’s in the 80’s which has affected my judgement).
There was a cracking Harley Davidson advert in the 80’s - ‘grow old disgracefully’
I’ll get the anthracite or silver paint on order Rolling with laughter
Post #965768 23rd Sep 2022 8:14am
By means of the calipers which replaced those I removed! Very Happy
Post #965769 23rd Sep 2022 8:17am
geobloke
What? really? Why on Earth? It's a protective coating. Does this mean we should inform our insurance bods if we waxoyl the chassis or paint the engine pulleys to prevent corrosion Shocked Rolling Eyes
I would like to think if I called up my local NFU office and said hey Dafyd just thought you should know I have painted the brake calipers on my Defender to prevent corrosion he'd just laugh hard and loud down the phone at me Rolling with laughter
Post #965776 23rd Sep 2022 11:22am
geobloke
Having only recently done this job on Miffy I can tell you I was surprised how long it took for the brush on paint to cure fully.
But... Once cured it is hard as stone.
I think part of the problem was the porch I was painting in was not very warm, so used our dehydrator to help the curing process. You could use a kitchen oven I suppose at its lowest temp. Maybe. The dehydrator can go as low as 43 degC. It still took 4 or 5 days to do the paint job well though.
I needed the paint ASAP and ended up with apparently wannabe Porsche yellow Rolling Eyes I had no idea the colour you chose had a bearing on your aspirations... I did stop before adding faux Brembo decals though... I went with yellow because it is the closest to opposite dark blue on the colour wheel Rolling Eyes
Anyway they look great behind the Boost alloys and under the Oslo Blue paint. Plus the brake dust appears to just wash off as well. Only time will tell whether the effort was worth it...
For reference I went with Foliatec paint from Amazon https://www.amazon.co.uk/gp/product/B003O3...8&th=1
Post #965777 23rd Sep 2022 11:40am
Screbble
Well I like them Thumbs Up
I prefer my pads a different colour though Whistle
Post #965797 23rd Sep 2022 5:29pm
geobloke
Thanks Screbble Thumbs Up I agree about the pad colour but hey I decided to try out a set of terrafirma pads this time around instead of the usual green stuff.
Ultimately I figure that when it comes time for the pistons to need replacing the body of the caliper will be in good shape. Hopefully Rolling Eyes
I will say this though. Fitting new functioning calipers, MC and servo has transformed the braking of Miffy. Much more so than when I fitted drilled and grooved discs and uprated pads.
Post #965856 24th Sep 2022 10:14am
Grenadier
Nice. I’m mulling between that yellow and their burnt orange, to contrast my Corris Grey. Good inspiration though 👍 Monsieur Le Grenadier
Post #965934 25th Sep 2022 9:40am
geobloke
I really wanted the burnt orange Rolling with laughter It would have been much better with the dark blue. But when you need it NOW you take what's on offer Rolling Eyes
Post #965937 25th Sep 2022 10:12am
Page 2 of 4 <1234>
