![]() | Home > General & Technical (L663) > spacers on stock wheels / tyres |
| Kiter25 Member Since: 19 Sep 2021 Location: Beauly Posts: 231
25mm spacers front and rear with stock 20, no issues.
Click image to enlarge Click image to enlarge 23my p400e x dynamic hse, fuji white, towing pack, comfort and convenience, e diff, activity key, 3 zone climate, cold climate and a host of accessories. Now gone. |
| The_Liiicht Member Since: 07 Sep 2022 Location: Angus Posts: 20 |
You'll need to cut your studs down with 25mm and 20mm spacers though. This put me off 😑 Pangy 90 HSE 250 with off-roady bits 🏴 ⛰
| pascal Member Since: 24 Nov 2013 Location: Nicosia Posts: 21
i think not with OEM 20" alloys (5098), they have open spaces at the back between the lug holes.
| XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 553 |
I was wondering the same thing on spacers - thanks Kiter. It's kinda hard to tell from the photo angles - Do they sit flush with the bodywork or poke out a bit? Which spacer manufacturer did you use? |
