Home > In Car Electronics > Blown Fuse - interior light circuit
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
It seems on Friday when I reinstalled my front interior light (using the existing harness - so I know the wires are attached in right order) This blew the 10 amp interior lighting circuit.
This also knocked out the stereo head unit, and weirdly seemed to make the trip computer reset if I turned off the ignition for a reasonable period (not sure how long, but it's not instant)
Removing the interior light and replacing the fuse and the stereo has come back to life and the trip meter has now remembered 2 journeys.
I've recently done a load of work on the car installing things like roof console and a few accessories. I'm guessing I've made a mistake somewhere and somehow installing the light has completed a short, but as I'm using original harness that worked fine before I can't work out what.
Any Ideas? Fairly sure I haven't pinched it in the a pillar trim as part of what I did was install the mud deep trim
Post #964670 11th Sep 2022 8:50pm
LR90XS2011
remove the fuse, reinstate the interior light fitting and then refit the fuse.
see it it blows again;
the interior light has a permanent live and the negative is switched so easy to blow the fuse if removing or refitting the light fitting guess how I know? DEFENDER 90 TDCI XS,
Post #964672 11th Sep 2022 8:57pm
Balvaig
You can blow the fuse just by changing the bulb Big Cry I did.
Just takes the slightest misalignment to short.
You should be ok if everything working again.
Post #964703 12th Sep 2022 8:16am
When I had mine apart to fit a third interior light, I fitted plasticard insulators to the backs of each unit avoid exactly this:
 Darren
Post #964713 12th Sep 2022 8:57am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
@LRA neat as always Thumbs Up
Why LR decided to use the same fuse for light, clock, radio AND instrument cluster and OBD socket is beyond me. Maybe during development an engineer used slang for 'clock' and 'lights' (i.e. odometer, warning lights) and someone thought "oh, great, there's already a fuse for that. I can make my boss happy for re-using that one." Razz
Post #964762 12th Sep 2022 4:26pm
balmybaldwin
great news, thanks all, will look at insulating it
Post #964924 13th Sep 2022 9:02pm
