![]() | Home > Maintenance & Modifications > Rust prevention side effect |
| Landymatt Member Since: 31 Dec 2018 Location: York Posts: 204
All credit to a very thorough coverup operation for those Fox dampers you (haven’t) fitted!
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3747
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673
I wonder if I can spray the wife with the stuff for all the same positives you mentioned…….
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
ACF 50 is good, but I’d keep it off anything rubber where possible.
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274
ACF50 is excellent. I love it. I over-use it…
If in doubt about its magical powers just research it’s use in the aeronautical industry or biking (of the motorised type) community - and of course the Defender community. As Steve says, it’s wise to try not to saturate old or natural rubber. Technically ACF50 doesn’t have a negative effect on ‘new’ rubber or polyurethane, but it can have some unhelpful impact on older natural rubber. Same as oil and grease really. Occasional overspray won’t hurt. And yes I too have had a similar effect of ‘quieter’ and ‘softer’ ride when I’ve applied it (not always deliberately) on or around my polyurethane bushes - and not a Fox shock in sight. 👍 |
| nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 |
Do you use the liquid acf? if so what do you spray with? Last edited by nitram17 on 10th Sep 2022 10:15pm. Edited 1 time in total |
| steveww Member Since: 05 Jan 2022 Location: Malton Posts: 610
Yes I use the 1 litre bottle from the usual sources. I put it a small trigger pull garden sprayer. It takes a bit of adjustment of the jet to get a spray.
As I have a compressor I’m considering using a Schutz gun or a high volume spray gun as an alternative. |
I’ve only ever used the aerosol, plus the brown internal Dinitrol and external black wax.
Been happy with these three for years. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I might get a 5 litre tub and give the garden sprayer a go ...must be the cheapest option if you an manage to get a good spray pattern. |
Exactly the same Steve - 3 good things 👍 With ACF50 I only use the 13oz spray can. The 5l tin would be more economic but it’s not as convenient - especially if like me you are always noticing something that could ‘do’ with a bit of ACF50 when you are getting in and out |
| jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 983
Is ACF50 the same thickness as Lanoguard? If so a decent squirts bottle will be enough to apply it. I was going to purchase some Lanoguard but see that their prices have jumped recently.
Jim |
