![]() | Home > Td5 > Bolt type please |
| DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1498
Hi, the screw type is a Button Head Socket Screw.
Thread diameter and length can be measured from your existing ones. Screwfix can supply them in stainless. Typical example, https://www.screwfix.com/p/easyfix-button-...pack/8878t |
| The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303
Another option are Black Anodised Aluminium, they be less bling than bright stainless steel :
https://www.pro-bolt.com/aluminium You'll need to check the diameter of the corroded ones, and maybe order washers and nuts to match the bolts. Pro-bolt are not the cheapest, but they are designed for use on motorbikes so are properley outdoor proof, www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891
Or black stainless steel....
https://www.carbolts.co.uk/?gclid=Cj0KCQjw...J5EALw_wcB |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347
Now they are a bit nice! Particularly like the etched version |
Used for the Grill A/C mesh refurb :
Click image to enlarge Click image to enlarge 3 years now and the Pro-Bolts still looking perfect (the aluminium mesh - not so great www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Nice
