Home > Puma (Tdci) > Fox Shocks Advice |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1867 |
The shocks come with their own washers and bushes but i presume you mean the washer in the turret? i reused mine they were like new, i would contemplate fitting new shock turrets, i wish i had done this to mine at the time.
Great shocks though, you will need an extra hand you help push the turret down to secure in place the fox have a lot more resistance to the OEM 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
24th Jun 2020 8:56am |
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 |
Thanks for the tip bear! I am fitting all new hardware from gwyn lewis including turrets, spring seats, retaining plates etc. I was more referring to the smaller washers with the lip that centralise the shock in the turrets and base. I can't tell from the images of the shocks as to whether they come with them.
Click image to enlarge |
24th Jun 2020 9:07am |
They come with the upper and lower washers, i reused mine in the turret (wish i had done the turrets at the time, anyway a set on order for a future fit) mine didn't have them on the lower end just the top, i don't think it will make a great deal of difference if you added them though
24th Jun 2020 9:27am |
red-scirocco Member Since: 28 Jun 2012 Location: South Norfolk Posts: 13 |
Id recommend ditching the poly bushes and fitting OEM rubber bushings. 2006 (56) 110 Td5 Double Cab
Instagram @110_td5 |
24th Jun 2020 12:16pm |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 401 |
Can I ask the reason for ditching the Polybushes please?
David |
24th Jun 2020 6:34pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2626 |
I really liked the supplied bushes,
Also get some YRM stainless washers for the rear extra bling factor. broke my heart reusing the old washers... got YRm now Click image to enlarge https://yrmit.co.uk/product/316-stainless-...r-classic/ |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3615 |
I couldn’t get in with the supplies bushes, so keep your old one case. Mine were too stiff and actually impacted articulation. My tears also didn’t come with the top washer and I had to put the dirty old ones one. Unlike LikeOMG mine are still on 🙁
24th Jun 2020 7:01pm |
Click image to enlarge Machine mine down to 20mm, still swapped them out for rubber bushings on the front axle with the correct washers. The rolling comfort and plushness is not there with the polyurethane bushes supplied. still using the supplied rear bushes atm, but going to try out Genuine LR ones soon. 2006 (56) 110 Td5 Double Cab Instagram @110_td5 |
24th Jun 2020 7:25pm |
Ah, I see, thanks
David |
24th Jun 2020 9:18pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 397 |
Sorry for the old thread restart, but the title is correct.
Just about to install Alive comfort springs and fox shocks. I have one pair of rubber gaiters. Do you need gaiters on front and back? Or do I fit on the fronts now, as they are a PIA to fit later, and then add to the rears later as that’s quite easy? Do you even need them on the fronts? I am assuming on the rears they are needed as the crud that gets chucked up by the front tyres will hit the rear shocks. I’ve looked on here at various threads and photos of other peoples installs do not seem to have a common solution. |
10th Sep 2022 8:50am |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2158 |
I have 🦊 front and rear. They do not come with gaiters. GET SOME. The rears were replaced under warranty for leaking out all the oil due to seal damage caused by stones. Rears only required.
10th Sep 2022 9:48am |
Thanks Keith. Rears only then.
10th Sep 2022 10:19am |
(Pro comp ribbed protection) from Gwyn Lewis. Ziptie top and bottom.
No I didn’t know he sold condoms either |
10th Sep 2022 10:24am |
