![]() | Home > Puma (Tdci) > Crankcase Pressurised |
| Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306
My 2015 110 65,000 mile has decided to re-decorate the engine bay with smelly oil and it’s got a little bit of blow by on removing the filler cap.
Copper washers / stretch bolts / Cam gasket and an injector seat cleaning kit coming on Monday. Is it good practise to lightly lube copper slip on the copper seals to help them locate or will this make a grinding paste, destroying the seal? |
| Puma22 Member Since: 22 Jun 2022 Location: North Yorkshire Posts: 29
I didn’t use anything on the washers and had no seal problems. A kit to remove the old ones might be needed if they are passing.
I would also considering looking for oil in the intake/poor compression. I started off thinking I had blow by, but in the end I needed a new piston. |
| Chuchi_EL Drac Member Since: 21 Aug 2014 Location: Valladolid Posts: 15
Click image to enlarge Here is a holed 3rd piston of 2.4 2010 95.000Km and injectors checked OK |
| rillas Member Since: 27 May 2012 Location: warilla nsw 2528 Posts: 16
hole in piston just did acomplete rebuilt did myself no body would do it went at 146450 km replaced every think big job lucky kicked over first go i think better luck then management
