Home > Puma (Tdci) > rear flange, question about safe to drive?
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
So thought a dog had released themselves on my rear wheel, cleaned it off and it was oily.
so investigated more and took the plastic cover off (which was cracked so letting out the oil...
Now its driping out at a rate, of about one drop every 5 seconds, the car is also angled over to that wheel at present when parked (so oil over to that side of the axel)
I guess a seal has gone inside, and not just a drive flange, so thats a dismantle the end of the axel, does anybody do a complete kit for the replacement of that seal? if so anybody have the part number, have searched on here and came up with blank, the breather does not look blocked and not taken off the drive flange yet.
Also any ideas if I could drive say 30km with it like that no probs or is that asking for issues?
thanks in advance. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #964265 7th Sep 2022 11:39am
Race.it
further investigation, there is movement from 12-6 position very slight, but no movement 3-9 position when pulling on wheel, so I am guessing my wheel bearing is also on its way out Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #964266 7th Sep 2022 11:50am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Can you park it on the flat and see what it does. If you're thinking of driving it, that would give you a better idea of how it will be and the rate it drips during the drive.
I replaced my driveshafts recently, and the outer gasket that holds the drive flange on is only thin paper. They're very cheap at all the normal suppliers.
you can change this without even taking the wheel off. just park (or jack it) so that the oil is at the other end of the axle. easy to do at the roadside, so no need to drive it to anywhere. As long as you have the gasket.
I don't know if there's another seal further in that should stop the oil getting to the flange gasket. I'm sure someone else will comment in on that.
Post #964267 7th Sep 2022 11:56am
Race.it
Funny you say that, just done exactly that, hence checking the wheel bearing.
No oil comes out when its level.
Ordered a new flange gasket, new grease cap, as one that was on there was lets just say Censored . Also ordered a timkin bearing to have ready for a future day. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #964275 7th Sep 2022 12:44pm
Dinnu
Being the rear axle, and have play at 12-6 and not 3-9 I suspect that the stub axle is worn. It happens when the inner race starts spinning on the stub axle.
Do not bother with the inner shaft seal. Many remove that so as to keep the drive members lubricated by the diff oil.
Driving with the dust cap off will not hurt your Defender, but will have some oil on the wheel and tyre. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #964290 7th Sep 2022 2:27pm
jst
Just replace the cracked plastic cap. Nfa needed. They are better without axle end seal to keep dm lubricated. It's only front 12/6 and 3/9 wear that indicates King pins or bearing anything rear wear is bearing related. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #964296 7th Sep 2022 2:50pm
Race.it
So stub axel for xmas 😂😂 Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #964310 7th Sep 2022 5:07pm
