Home > Td5 > Webshop recommendation (in UK or European Union)
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
My TD5 110 is at the workshop and quite some seals and gaskets have to be replaced. My mechanic told me if I can get him the parts cheaper through a community recommended shop (rather than source the parts in Switzerland) it would be a win-win. This also given he would not have to spend time for searching parts.
Are there any particular recommendations where you are getting your parts?
For the doors and windows: As I need to replace all door and windows seals I was hoping to find full replacement kits instead of having to hunt down the individual parts
I'm aware of this shop and the prices seem to be on the fair side but am still to new to Defenders. Expertise is more with Datsuns at the moment.
https://www.sp-4x4.com/land_rover_defender_parts_s/103.htm
Would be much obliged for pointers.
Post #963900 3rd Sep 2022 4:45pm
Honeyman
Netherlands 2011 Defender 130 Puma 2.4 HCPU Sumatra Black
I use lrdirect.com when I can’t get things locally (most of the time Rolling Eyes ). Quick turnaround, often many options for the same part number and prices (in euro for me) include import duties up front rather than being paid later to the courier. They have the option for pricing in Swiss francs. No affiliation…. Just convenient and never had problems.
Good luck! 2011MY 130 HCPU: daily driver
1979MY RRC 2-door: on the drive, in the garage & in a shed - all at the same time.
Post #963906 3rd Sep 2022 5:38pm
Dinnu
I have used Paddock Spares many times. They also offer ddp shipping (Delivered Duty Paid) so you pay at your local vat rate. The price you see is the price you pay. They have both aftermarket, OEM and genuine. Most searches with part number will result in aftermarket. If you add a ‘G’ at the end it would be OEM.
No affiliation. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #963911 3rd Sep 2022 6:42pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
grüezi Wink
Not sure if postage to Schweiz is cheaper from Germany than from the UK? If so, there is
https://allbrit.de/select.cfm?CAR=L8&SPRACHE=DE#
where you can find parts by selecting them in the diagrams, similar to
https://www.lrworkshop.com/diagrams/land-r...ssis/doors
where you click on a part and get a list of "the usual" UK suppliers such as lrdirekt, paddock.
More Germany-based shops I can recommend are
https://allrad-kontor24.de/shop/
https://www.landy-scheune.de
Re the door seals it seems genuine one are far better than Britpart (I think Mike of britannica restaurations had a video about it? Genuines have a different profile and material IIRC.)
Post #963926 3rd Sep 2022 8:54pm
doruk1981
Many thanks for the recommendations.
UK or Germany - its not much of a difference. Shipping has some weight thats all. one of the UK shops offers for 1k the whole rear-right door which i'm looking at. Just need to ask my mechanic to measure the button size on the door handle that i order the right one (not sure of the purpose of said button) given that there is no lock and its central locked...
Whats kind of not too intuitive is that the seal section for the rear doors is always missing - LRWORKSHOP or the Allbrit only offer the front seals and the rear door's seal. given the door has a different shape, i cant imagine that the front seals also work with the rear ones?
But otherwise the pages are really neat to navigate and get familiar with the 99'999 parts that will make my Mortimer better than factory new.
Post #963986 4th Sep 2022 5:17pm
macfrank
99,999 parts indeed Smile
Do you mean the rear side doors' seals are missing from the diagram?
They're here I think https://www.lrworkshop.com/diagrams/land-r...me_52743#2
And which button are you referring to?
Post #963992 4th Sep 2022 5:57pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
For online orders I’ve personally found island 4x4 to be the most efficient and their prices seem to be competitive for most things.
https://www.island-4x4.co.uk/
Post #963998 4th Sep 2022 7:31pm
doruk1981
I see now .. funny that they did an own section for front door seals but not rear ones.
its nice to see that the seals are all rather economic if not ordered LR branded
In regards of the push button - S&P have the interesting plug and play (after paint) option which is interesting. However they also state you need to do a selection regarding the push button size. I know my handle has also that button (not sure whats the purpose of it) but as an (early) 2002 model i'm not certain if I need to order the 18mm version or 20mm version...
Post #964038 5th Sep 2022 8:42am
macfrank
ah now I get it - I didn't notice this is the TD5 forum section Embarassed Later model don't have that mysterious extra button, so someone else may shed a light on its purpose?
Post #964044 5th Sep 2022 9:00am
All civilian Defender doors have push button handles, regardless of whether TD5 or Puma (or Tdi, etc.). The size that SP4x4 refer to in their listing is the diameter of the hole for the lock in the drivers door handle, which is either 16mm or 20mm:
I'm not sure about the dates that they've quoted for changeover - I thought the change from 16mm to 20mm came with the introduction of the pressed steel 'Puma' doors in the last year or so of the TD5, but I could be wrong.
Anyway, telling the difference is easy: if you have a single key for the ignition and door lock then you have the later 20mm lock barrels. If you have two different keys then it's the earlier 16mm type. Darren
Post #964050 5th Sep 2022 9:34am
doruk1981
Thank you for the explanation - I indeed use the same Key for door/ignition. So the 20mm would apply. However given that the door is a rear passenger door - wouldn't it be applicable to get the "Blanked off lock hole" version? Given I don't have any lock barrels sitting in the door.
Post #964052 5th Sep 2022 9:42am
macfrank
haha, so much confusion about a hole Laughing Thank you LRA.
https://www.britannica.com/story/is-a-hole...thing-isnt
"However given that the door is a rear passenger door - wouldn't it be applicable to get the "Blanked off lock hole" version?"
There seems to be no reference to that 'not-a-button' in their rear door listings.
Post #964053 5th Sep 2022 9:50am
Yes, but their rear door pages don't give that option anyway. The choice there is either manual or central locking.
 Darren
Post #964054 5th Sep 2022 9:51am
Dinnu
A 2003 Td5 has the 20mm hole. So seems like site is correct. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #964065 5th Sep 2022 11:50am
PocketFred
Switzerland 2001 Defender 110 Td5 HT Caledonian Blue
I have used Paddock, LRParts and LR Direct to ship to CH, they all handle customs so it was super easy.
I have also ordered from YRMT for body parts, they sell VAT free and you pay VAT at reception. Also super easy.
Cheers from Lausannegeles Cool 110 HT TD5 w/ PopTop for travelling
110 CSW 300tdi for hunting
Post #964092 5th Sep 2022 4:49pm
