Home > Puma (Tdci) > Injector stretch bolts & new seals.
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Having had to whip the injectors out on a hillside ( long story) I’m about to fit new copper seals & stretch bolts, is there anything more than changing the copper washers & fitting the stretch bolts to the correct torque?
It ran fine afterwards but want to do it properly so it doesn’t come back to haunt me!
Anyone know the torque settings by the way? 2.2 2012 cheers.
Post #963687 1st Sep 2022 5:05pm
hank
Clean the counter bores and injector seats scrupulously clean. Any carbon buildup will lead them to leak again prematurely > 110 XS Double Cab
Post #963712 1st Sep 2022 8:36pm
Balvaig
From the 2012 workshop manual.
NOTE: Note the position of the fuel injector clamp.
NOTE: Re use bolt only once
Torque stage 1: 6Nm, Stage 2: 360°
Hope this makes sense
Xxx. Possible correction. xxx
On the general spec sheet for the ID4 2.2 engine the stage 2 is given as 180
Hopefully someone who has changed the injectors will be along to give you the correct Stage 2.
Sorry for the less than helpful reply.
Post #963728 1st Sep 2022 10:08pm
A curious remark! Does that mean the bolts can be used twice in total, or is it sloppy writing (sadly common in recent LR publications) intended to say "do not reuse the bolts'?
Post #963733 1st Sep 2022 11:19pm
Balvaig
Exact wording copied from page 579 of my electronic version.
The heading helpfully states “ Removal steps may contain installation instructions”
To add further confusion the Haynes manual states that the torque for the clamp bracket bolts is:
Stage 1 7Nm
Stage2. Angle tighten a further 180
Need to lie down in a dark room Shocked
Post #963744 2nd Sep 2022 8:27am
Timcat
Thanks for the info Hank, when you say clean how would you suggest cleaning them? Brake cleaner or would the solvent damage them. Sorry for asking obvious question but never had anything to do with injectors before.
Post #963782 2nd Sep 2022 5:26pm
Timcat
Stage 1 7Nm
Don’t quite get this, basically 7mn & then tighten 180 degrees?
Post #963786 2nd Sep 2022 5:40pm
ickle
I think you're spot on 7Nm then 180 degrees.
A friend who owns (and was 'hands on' for very many years) a diesel injection business always repeat always anneals the copper washers before fitting them - no matter who's manufacture, what colour packet, OEM or not it just ensures they will seal.
HTH Keith
Post #963788 2nd Sep 2022 5:54pm
Timcat
That’s interesting, they’re all genuine seals & bolts. Will look into it Thumbs Up
Post #963793 2nd Sep 2022 6:20pm
Timcat
Finally got around to doing this the other day, straight forward enough. Because our truck lives off road a lot of the time the only issue was cleaning the crud off around the injectors / clamps.
Post #964613 11th Sep 2022 8:40am
