![]() | Home > Maintenance & Modifications > Gloss Black Wheel arches? |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
I take it you have considered respraying your originals?
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Soulrider911 Member Since: 04 Jul 2022 Location: California Posts: 119 ![]() ![]() ![]() |
Sadly my originals where damaged when I bought the car. So they went in the trash. Shoulda thought this one through more… these things are not that easy to come by. But will figure it out
![]() 2022 Defender 110 SE DIY’er | Always learning |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3557 ![]() ![]() ![]() |
How badly damaged are the originals? if cracked they can be plastic welded? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
ya they were warped beyond repair... not sure how they got so warped but it was bad. But, I think I found a good set from Legends Overland, expensive as heck but worth it if they fit and are made well, which he said they are : https://legends-overland-global-parts-stor...amp;_v=1.0 1989 Defender 90
My originals, from 1988 are not so straight either. I always know them as such.. and I own the 90 since 1994. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Been there, done that.
The TF arches are poor quality and poor fit - I never managed to get them to fit in the end and chucked them in the skip. Ended up painting my originals satin black. Rgds. Chris |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
if you're OK with used Genuine Parts arches, why not just post a wanted ad here for some? A lot of people will be fine shipping them and being honest, its no more difficult for a seller to send something to the US than it is to send it to London. We normally just use parcel2go.com
Being old and crusty, the value can be declared low so that import taxes aren't too high. That way you can have them fitted as-is or you could have them resprayed. If you offered to return the favour for someone wanting parts from the US I'm sure you'll find someone that can help. |
