![]() | Home > Puma (Tdci) > windscreen frame rust.... concerns when buying |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
mine is a 2011 and had some corrosion on the bottom corner folds, repaired under warranty and has come back a little bit over the following 7 years, I just spray a bit of ACF 50 under the rubber and wipe it about to keep it at bay.
A window frame change or repair is not too onerous, I brought a good used one of an older model for only a few ££ off a fellow forum member just in case I need it in the future. have you photos? DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 30th Aug 2022 8:26pm. Edited 1 time in total |
robjstan Member Since: 30 Aug 2022 Location: Staffordshire Posts: 4 ![]() ![]() |
I've added the photos to the original post
![]() Last edited by robjstan on 30th Aug 2022 8:34pm. Edited 1 time in total |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3585 ![]() ![]() ![]() |
Seems like older frames are more resistant to corrosion.
Aluminium, unlike steel, is less corrosion resistant when it is highly alloyed. Probably later Defenders have a high alloying contents from all the different Heineken, Budweiser, Carlsberg... beer cans. I would not be surprised if the windscreen itself is made from Corona bottles ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1003 ![]() ![]() ![]() |
Personally, I wouldn’t worry. Better off seeing the blistering than a freshly hidden/painted frame IMO. 2008 2.4 110 Utility Station Wagon XS.
there is always that buddy, good call. The guy I'm buying it from is getting a patch done on the roof where a roof rack has previously been fitted and caused some blistering so I might if I go for it see how much the body shop will charge to do the windscreen frame at the same time. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
I’ve just had my 2011 Puma windscreen frame touched up as it had two areas that were blistering, caught early removed and treated properly is my approach to avoid it becoming a bigger issue quickly.
All removed now but this is the before… ![]() Click image to enlarge ![]() Click image to enlarge Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT Last edited by Leamreject on 30th Aug 2022 9:25pm. Edited 1 time in total |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
The top picture looks like a previous repair as it looks like the joint has been painted over so i would sand it back and repaint. ![]() Click image to enlarge |
I think you're right
My 2003 screen frame is fine, yet my chums 2015 frame looks awful, mine has done 168k his has done 32k, they must have cheaped out on the frames at some point.
I don't think its the frames as such but the quality of the paint job..mines a 2015 model and the paint thickness is atrocious.
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 607 ![]() ![]() ![]() |
They all do that.
My 2015 has some bubbling in the same place. My local Defender body shop has it as a standard list item. Screen out, sand back and respray. They did it in a day for £200. If the rest of the Defender is OK, do not let it put you off. Buy it, drive it, enjoy. |
have you sprayed the inside of the bulkhead with fertan and then a wax ?if you havent i would as the rust comes from the inside!you may slow it down! edit sorry i got disorientated i thought it looed like the bulkhead ![]() |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
I'm also with a 2015 and also in the abysmal, atrocious (choose your adjective) camp.
My truck has been garaged since new, alway stored clean and dry. Waxoyled professionally, annually. The windscreen frame was repainted and blocks were replaced under warranty at 5 years old. Pedantic, opportunistic Swiss painters, great job, bill of 1800 chf to JLR. And guess what? 3 years later the job needs to be done again. Roaming around 🇳🇴🇨🇭 Last edited by Angus_Beef on 31st Aug 2022 2:50pm. Edited 1 time in total |
Somehow I feel better knowing this issue might just be recycled beer cans. I love beer. ![]() |
