Home > Puma (Tdci) > Antifreeze and power steering fluid requirements
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
There's a great thread on oils for various bits.
What is the recommendation for antifreeze and for power steering fluid?
Post #963383 30th Aug 2022 4:45pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
It’s recommended that you don’t drink it… Thumbs Up Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #963386 30th Aug 2022 5:17pm
Email Opie Oils, or sign up to their site and it should show you.
There is a club discount too. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #963388 30th Aug 2022 5:28pm
Leamreject
Or try this Fuchs site used by our 80+ workshops. It says oil chooser but covers all fluids by simply entering your reg number
https://www.fuchs.com/uk/en/ Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #963393 30th Aug 2022 6:04pm
Ianh
Texaco Delo XLC antifreeze , orange in colour, Is the stuff LR use plus rebadge and sell as their own. It is really good antifreeze. Dilute 50/50 with deionised water, available cheap from supermarkets as people use in irons.
It’s not easy to come by in less than 20l concentrate cans but I got a 20l can from opie when it was in a clearance sale and with forum discount and free postage it worked out reasonable, noting given dilution and times between changing I now have at least 40 years worth but still cheaper than buying 5L from landrover Very Happy
Post #963420 30th Aug 2022 8:40pm
Leamreject
If your flushing your coolant completely consider using a modern coolant product that you don’t dilute and doesn’t contain water. Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #963426 30th Aug 2022 9:13pm
Ianh
”modern” does not necessarily mean better, I think the jury is out as to whether waterless coolant outperforms “Quality” traditional coolant mixed 50/50 with Deionised water. Evans seems to be the major provider of this technology, but reading reviews I would not go near it.
Each to their own, but I have not read any issues with the quality traditional LR coolant mixed with deionised water in puma Engines.
Post #963454 31st Aug 2022 2:33am
Bluest
For Power Steering Fluid, Opie Oils told me to use CHF (central hydraulic fluid) not ATF/PAS fluid. 2007 110 TDCi Station Wagon XS
Post #963467 31st Aug 2022 8:24am
Leamreject
Agreed, shame we have to find out the hard way. However opinions on waterless coolants do vary though so we each need to do what we think is best on the advice received for our intended usage. Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #963471 31st Aug 2022 8:54am
steveww
After some more research I've found.
STC50529 - Antifreeze
STC50519 - PAS Fluid
Searching for these part numbers finds products from the usual suspects.
Post #963485 31st Aug 2022 10:45am
HardCharger
How frequently should we be changing these?
Post #963611 1st Sep 2022 4:48am
Leamreject
I don’t think PAS fluid has any replacement cycle but for coolant circa 5yrs depending on use and working conditions. Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #963612 1st Sep 2022 5:21am
Ianh
Here is a serving schedule for a 2.4 puma
https://www.lrworkshop.com/servicing-sched...-2007-2011
And one for the 2.2 puma
https://www.lrworkshop.com/servicing-sched...-2012-2016
You will see the coolant spec is Wss-M97B44-D and that 120k miles (200,000 km) / 10 years is the renewal frequency.
The texaco delo xlc meets this spec, https://www.texacolubricants.com/en_uk/hom...olant.html
In fact when you read the customer benefits section in the above link they say it’s good for 650,000km !
With the caveat “These are general indications. Some OEM’s may have their own specific guidelines, and these should always take precedence”
I always go less on fluid changes, I.e no more than 5k miles between engine oil changes, so 60k miles / 5 years won’t hurt for coolant. I did mine at approx 60k miles when I replaced my main Radiator, I expect a rad fail will be less than 120k miles or 10 years so that will likely dictate coolant change interval more than service schedule.
I can see online that pre mixed 50/50 texaco delo xlc is available for £30 in a a 20l can, so that would be good for 2 changes , I.e 10 / 20 years worth.
Also I don’t see any schedule for changing PAS fluid
Post #963660 1st Sep 2022 1:20pm
HardCharger
Thanks for that, Ianh!
Definitely helps with maintenance planning.
I just finished watching video posted here recently about the effects of long oil changes as dictated by the owner's manual and it was quite concerning. The mechanic did mention the preferred change interval for engine oil but didn't go into such detail with the other fluids you should be minding in your vehicle.
I personally change oil and all filters (air, fuel, oil) every 10,000 KMs. I'm just figuring out a reasonable change interval for the other fluids as it's easy to visually check and top off but you do eventually have to replace what's in the system when the time comes. I'm only afraid that if we follow the manufacturer's recommendation that we may be setting ourselves up for premature wear and failure of components like what happened in the video.
What do you all think?
Post #963742 2nd Sep 2022 5:31am
keith
I was taught to “dip your finger in and taste it”
To know the strength and find out if needing to be topped up. Now I know why I glow green in the pale moon light Rolling with laughter
Strangely enough I get the same taste from sugar free ribena 🤮
Post #963743 2nd Sep 2022 8:24am
