![]() | Home > Maintenance & Modifications > Wheel carrier & alloy wheel |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2506 ![]() ![]() |
Worth checking out ORE https://ore4x4.co.uk/shop/land-rover-defen...l-carrier/. Well thought of on here, but worth a call to see if 18” Alloys will be ok with their carriers.
Noting that they can support big heavy 285/75r16 MT tyre setups that are circa 33 inch in diameter so I can’t think why they would have an issue with an 18 inch wheel tyre combo. |
TC909 Member Since: 27 Jul 2021 Location: Lincolnshire Posts: 39 ![]() ![]() |
Thanks, I did see that one £700 though....
Yep, about twice the price of the std one you highlighted , so not cheap but avoids any drilling and is designed to take significant weight and large wheel/ tyre setups. If you depreciate it over 10 years that extra £350 is only 67 pence per week
A member is advertising a spare wheel carrier on here https://www.defender2.net/forum/topic84567.html
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 300 ![]() ![]() ![]() |
Second vote for ORE - Awesome bit of kit, so worth the money, even if its for peace of mind to prevent the rear door from stress cracking in the corners due to the normal boost alloy and tyre combo. Have a word with Chris McC hes on this forum as chrismack85 or via this topic about wheel carriers : https://www.defender2.net/forum/topic84063.html Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
There's no technical reason why that carrier shouldn't work with 18" wheels. Going smaller may be an issue but bigger just means that there's more clearance behind the wheel. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
