![]() | Home > Puma (Tdci) > Switch to turn on/off aux. external lights |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511 ![]() ![]() ![]() |
In addition to the thread Lorryman100 has linked to in his above post, which mainly refers to the earth switching Auxiliary Lights switch YUG000540LNF, there is also the live switching Heated Seat switch, that fits into the bottom two positions that you've green arrowed -
![]() Click image to enlarge These switches are still relatively cheap compared to some of the other switches - http://www.rimmerbros.co.uk/Item--i-YUF500150LNF ![]() They use the readily available Black connector - http://www.ebay.co.uk/sch/landrover-connectors/m.html ![]() The switch and its connector are wired as follows - Pin 1 - Live in from Fuse Box Pin 2 - Dash illumination Live Pin 3 - Not used (but is internally connected to Pin 5 - Earth) Pin 4 - Switched Live out to Seat Heaters (or accessory) Pin 5 - Earth . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 18th May 2012 1:33am. Edited 1 time in total |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Thanks for the useful P/N information and links!
