Home > In Car Electronics > Flip image on optimill reverse cam and alpine head unit? |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
never noticed ..i will have a look at mine .... im assuming if you rotate the camera ball 180'i the unit the picture is upside down/reversed?..just looked mine is the same ..i just use it for a quick look to make sure nobody is behind me (kids ect).....I would be interested to see if there is a fix?
20th Aug 2022 12:50pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3618 |
I assume that will be the case, although I haven’t actually tested the theory yet!
20th Aug 2022 1:05pm |
how is yours wired?via reverse switch or permanent and switched off/on at the unit? Do you have the banner at the top saying look with your eyes?
edit i have found this https://manuals.plus/cs/jvc/kd-x561dbt-opt...z7cVRqlEcJ it may help as it talks about reversing image...I haven't got time this weekend to fiddle so i will be watching this thread with interest. |
20th Aug 2022 1:09pm |
Mine comes on with reverse. Just read in the MUD guide that you cut the two loops of wire hanging out of the camera flying lead. I’ll try that this afternoon and let you know.
20th Aug 2022 1:35pm |
Can confirm, I cut the green loop only and it has flipped the image the correct way.
20th Aug 2022 1:56pm |
ive got mine wired with the reverse .but im thinking of changing it to a direct ignition on feed as there are times when in traffic that it would be advantageous to have a view of the rear blind spots without the need to put it into reverse.
20th Aug 2022 5:16pm |
Which end is this green loop ?at the camera end or head unit end? |
21st Aug 2022 3:23pm |
It’s on the camera end.
21st Aug 2022 3:28pm |
21st Aug 2022 4:09pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1782 |
Co1....showing my age here, but did it feel like you were in an episode of “Danger USB” as you hovered over the green wire with your side cutters just before you eventually cut it
21st Aug 2022 4:39pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1871 |
Thinking of one of these for my next purchase, any pics of the picture or your review on the quality of the picture etc 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) Last edited by bear100 on 21st Aug 2022 10:21pm. Edited 1 time in total |
21st Aug 2022 7:33pm |
That's a blast from the past danger UXB or can you remember doomwatch ..robert powel trying to defuse a bomb on the end of a pier..one way to end a series. |
21st Aug 2022 9:37pm |
The picture is fine but be aware there is a huge blind spot in the image due to its off centre positioning ..it has a 170 degree camera arc.I have mine set so the transition of the yellow to the red tramline is one foot away from the nearside corner and one foot from the middle of the truck on the offside. |
21st Aug 2022 9:44pm |
hi col by right of by car do you mean drivers /offside? im not sure whether I'm having a senior moment ..have you installed the optimil number plate camera unit or just the stand alone camera?the reason i ask is that i took a look tonight at my set up (NP unit)and there was no wire loop as described by mud to cut! https://www.mudstuff.co.uk/collections/opt...rse-camera i used the mud kit with the light piggy back. There is only one lead from the camera!so im a bit stumped as if you look on the mud website it gives you this picture as an example unless that's a left hand drive that image is reversed isnt it?(spare wheel to right) or am i in need of a DAT scan.anyway that's how mine looks !any solutions? |
21st Aug 2022 10:19pm |
