Home > Maintenance & Modifications > Calling all owners with Tailgates….drop down or swing?
Grenadier
Wotcha.
I’ve been mulling over adapting my tailgate from drop down to swing. I use the truck bed A LOT and when I didn’t have the hood, access into the back was easy from all directions, including the sides when getting at something sitting under the rear window.
But since I added the hood, it’s an effing nightmare leaning in and over the tailgate when in its lowered position. And I’m sure side access will be equally difficult, even without the hood on, when I finally get around to fitting the full SW roll cage.
So I’m thinking of changing to a swing tailgate to make access easier, (and also should work better with my yet to be fitted Mantec wheel carrier), but I’m just wondering if any of you out there who’ve made the change from drop down to swing, have regretted it? I do like the usability of the tailgate to perch on, use as a table, etc, but I think it’s benefits are outweighed by the cocking about i have to do to get anything from deep inside the bed. Having a ‘table’ could easily be rectified by having a slimline extendable bed.
But generally speaking, any thoughts? Any regrets? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #961962 17th Aug 2022 9:47am
geobloke
How about a load bed slide?
For example https://www.vanimal.com/heavy-duty-sliding...-QQAvD_BwE
Post #961964 17th Aug 2022 9:53am
Grenadier
Yup. Sort of what I’m thinking but with swing away gate. Monsieur Le Grenadier
Post #961966 17th Aug 2022 9:59am
How about the best of both worlds:
http://www.purelymetal.co.uk/set-of-double...te-hinges/ Darren
Post #961967 17th Aug 2022 10:01am
Grenadier
LRA. You’ve nailed it. That is exactly what I was wondering about doing. Best of both worlds. Thank you for that. Have a brownie point. Thumbs Up Bow down Monsieur Le Grenadier
Post #961968 17th Aug 2022 10:07am
Why, thank you Laughing Darren
Post #961971 17th Aug 2022 10:32am
I favour the drop down myself. It is a useful seat/table/workbench/step, and it discourages me from whacking my kneecaps on the tow hitch. If I need to reach further in I kneel on the tailgate. Finally but replacing the split pin on the RH hinge with an R-clip of an appropriate size (or simply binning the split pin) it is the work of second to remove the tailgate altogether (although it helps if you replace the awful plastic-coated wire stays with Series-type bagged chain stays).
Post #961975 17th Aug 2022 11:24am
Grenadier
I have to do a little jump/hop if I’m to get anywhere near kneeling on the tailgate. The stays are frigging tiresome, I shall check out the series versions. Ta. I might just put a swing door on and then fashion my own bed slider to replace the seat/work bench set up. But first I need to do a graph and work out how many times I use the tail gate as a workbench versus how many times I get fed up trying to get stuff in or out of the depths of the tub. We’ve been doing extensive work on the house and garden and at 5’8”, putting in, let alone dragging out, bag after bag of 35kg ballast/sand/cement is just a balls ache. Or 25 breeze blocks. Or 140 bricks, put in laced removed, one by one. Etc. Etc. Big Cry Monsieur Le Grenadier
Post #961998 17th Aug 2022 3:03pm
Bundy
If you make it swing you can't carry oversized loads as easily...
That was my main reason for leaving mine drop down.
I'm a dab hand at removing the cables to drop it out the way to load the back as I have a lid that prevents most side access.
Al
Post #962104 18th Aug 2022 10:31am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
The cables on my drop-down tailgate unclip in seconds if I want to lower it out of the way, although this isn't ideal if you have a towbar (see all the dented tailgates where careless/uncaring users have whacked it down hard).
Surely an inexpensive set of releasing cables and the correct brackets is the simplest/easiest/cheapest solution?
Post #962106 18th Aug 2022 11:03am
Grouse
Another vote here for the Purely Metal Tailgate hinges - it gives you the best of both worlds - I paid a bit extra, got them galvanised and then painted with a rattle can
Post #962209 19th Aug 2022 6:06am
Litch
I have side-hinged (have for over 20-years) and the WH carrier attached to it so they swing open together.
Works for me. ONE LIFE, GET IT!
Post #962309 20th Aug 2022 10:34am
seriesonenut
Pretty sure if you search on JOW240725 's posts you will find James has bottom / side hinge's fitted to his V8 Ninety when he converted to a soft top. 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #962316 20th Aug 2022 12:48pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Every pickup I’ve owned I convert to swing away, so much easier to use, especially if you get a wheel carrier…( choose one that bolts to door)
Easy to do as well, I use a leather check strap or a rear door stay to keep it open.
Next handiest addition is a sliding drawer, massively increases usability, can also get a sliding floor such as mine was before I converted it to aid getting things out.
I’m a landscaper/ timber buildings constructor so my pickups always get worked..
Cheers alex 98 300 tdi 90 project
88 200tdi project soft top
96 disco 1 jap import
79 911 sc
08 130 double cab utility
Post #962401 21st Aug 2022 3:18pm
