![]() | Home > Td5 > TD5 Defender poor starting |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 993 ![]() ![]() ![]() |
I have an iCarsft 930 it will read clear and show live data. It works perfectly on my 99 Td5. They sell uber cheap on eBay. The latest model is iCarsoft LR 3.0.
Good luck 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3386 ![]() ![]() |
Faulty battery causing too much of a voltage drop when starting, or faulty alternator which messes up the ECU
Have you changed the crank position sensor? And was the replacement starter motor a new one? As an electrically "noisy" starter can cause the same issues. I had the same fault on our 2005 TD5, after changing everything it turned out to be the starter . lt started the vehicle okay but caused issues with the ECU |
Jpu121265 Member Since: 13 Aug 2022 Location: Normandie Posts: 8 ![]() ![]() |
Thanks for the replies.
The code reader I'm using is an Icarsoft CR MAX, when plugged in it will only offer Lucas GEMS as a powertrain ECU and won't connect. I believe the GEMS is for the V8 as fitted to Discoverys. Have spoken to Icarsoft support about it and the concensus seems to be that it is unable to connect as the TD5 ECU is not fully OBDII compliant. I guess I could buy another Icarsoft reader but I'm a bit reluctant to buy another version of the same product I already have! The alternator was replaced around two years ago and shows 14V when running/after starting. It had two batteries, I only reconnected one. Then wired then both in, tried the other then tried the battery out of mine and it doesn't seem to make a difference. The crank position sensor I pulled out of another TD5 that starts/runs fine, so I don't think it's the sensor itself, but could be the wiring. Replacement starter motor was brand new. I still have the old one, I'm pretty sure it only needs a solenoid kit but I can't seem to find one over here so I could try cleaning it up and putting the original starter motor back on. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
Have you done a compression or leak down test?
Just out of curiosity, what happened to the previous 2 engines? Td5s are generally very reliable and long lasting. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Hi, no compression test. It runs sweet as a nut when it's running. Not sure how to perform a leakoff test on TD5 injectors? I'll look into it.
The original engine died when a hose blew (presumably coolant hose). Another second hand unit was fitted by a garage, but it never ran properly, it was then passed on to another English mechanic who fitted, supposedly, a 'reconditioned bottom end' (not sure of any firms that exist who do a recon block only so I suspect it's another second hand unit). |
A leak down test determines if there are leakages either past the piston rings, or the valves. Different from injector leakage. Cranking is slower than idling, small leakages will not affect idling, but starting could become problematic.
My old 90 had massive cracks in the pistons, but ran sweetly once started (barring the fumes), probably sweeter than new since there was not so much of compression to make any big bang. Bad luck with the coolant hose. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I'll have a look, obviously can't use the heater plugs as there's only four so not a meaningful test. I guess it means finding a competition tester to fit where the injectors go, and removing the fuel pump relay and cranking.
I would be very interested to see what the cranking RPM is, but a bit loathed to fork out €650 odd just to find that out! Asked a few garages and no one has any diag that is compatable. I'm sure my old Delphi could tell me a few basic things like injector misfire and the like. |
