![]() | Home > In Car Electronics > Alpine Double Din to optimill reverse camera set up help |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Check the head unit wire that grounds to the handbrake switch Roaming around 🇳🇴🇨🇭
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3747 ![]() ![]() ![]() |
Cheers Angus. Can you expand on that? I haven’t got the handbrake wire wired up, is this a necessity? Is there a workaround to save me having to run more wires in?
Cheers Col |
I have the JVC that mud sells and it has a wire to connect to a handbrake that needed to be grounded before the camera would work. I grounded this wire to the unit instead of hooking it to the switch because I wanted everything to work regardless of parking brake position .
I’m not sure if your particular unit is the same, but with mine the camera did not work with that particular line not connected to a ground Roaming around 🇳🇴🇨🇭 |
Cheers Angus, I’ll give it a go.
Sorry, just to clarify, all I need to do is connect that wire to ground?
Well I don’t have the alpine unit so I can’t say for certain. But in your trouble shooting, check to see if there is a line for the parking brake, and what signal the unit expects on that line Roaming around 🇳🇴🇨🇭
There is a parking brake line, but not sure whether it wants 12V or 0V. I tried grounding it to no avail. Worth connect it to 12V or do I risk booting something?
MichaelE Member Since: 18 Jan 2020 Location: Crawley West Sussex Posts: 155 ![]() ![]() |
Not saying this will fix your problem but you may want to do an Ebay search for "parking brake override bypass". You'll find them for a range of units and Alpine are amongst them. It allows access to menu items that are unavailable if the unit does not get a handbrake on ground signal.
Problem solved. Turns out you have to enable the camera in settings!!!!
Good result!! Roaming around 🇳🇴🇨🇭
