Home > Td5 > Injector colours
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Injector colours
Asking for a friend (as I run a a Puma) He’s got a 130 TD5 it’s a T99, when bought it ran well & pulled hard. An injector went down ( years ago) & he had it fixed by an independent specialist.
Since then he’s had it in and out of numerous places as it lacks power & struggles up hill.
Earlier this week he discovered the injector that was changed is a different colour to the rest, would this make a difference or have any significance?
Thanks in advance.
Post #961317 11th Aug 2022 9:42am
Timcat
Forgot to say 4 blue & 1 green.
Post #961318 11th Aug 2022 9:44am
geobloke
Could do with a bit more information on the engine. It should be a 10P engine in a 99MY but do you know whether it still is a 10P engine or has had a replacement later 15P engine installed. Is the ECU an MSC (early) or NNN (later) ECU? Is the fuel feed internal (10P) or external (15P black hose under intake manifold)? It is possible to have a 10P block and a 15P head Frankenstein engine if it has been "upgraded" when a head died.
Blue/Black Injectors = Earlier 10P and MSC ECU 1500psi Short travel piston
Green Injectors = Later 15P and NNN ECU 1700psi Long travel piston
Whether a 10P or a 15P engine it should really be fitted with 5 injectors of the same colour.
Post #961323 11th Aug 2022 10:50am
Timcat
What a wealth of information, many thanks for the in-depth reply. I’ve asked my friend for as much information he has & will post it up when I know more.
Post #961326 11th Aug 2022 11:02am
KISSMYAURA
United Kingdom 2003 Defender 90 2.5 TD SW Epsom Green
15P GREEN!
Post #976453 2nd Jan 2023 9:43pm
alexatnd
Hi,
ok thats informative thx
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #1039192 5th Jul 2024 10:52am
