Home > Technical > 89 Defender 90 have to SLAM doors?
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey everyone. hoping to get some direction on how to reconcile my doors. So I have to slam the heck out of my doors to close them. The right window is already loose, most likely from the previous owner slamming it as well. I attached a video as I figured would be most helps-full rather than reading a ton of text. Appreciate any help Smile
 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #960973 7th Aug 2022 11:46pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Reminds me of mine when I first got my 90. Although my door seals looked new and appeared good I had to replace them with genuine LR ones to improve it.
There are some clips on here showing the difference between OE and aftermarket, any small change in firmness makes a huge difference.
 Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #960980 8th Aug 2022 6:19am
Mo Murphy
Soulrider,
I'd like to have seen your door set when latched on the video.
I suggest that the striker on the door jamb is too far inboard. These are completely adjustable, up down in and out so be very very careful adjusting their position. You only want to slacken the screws enough that it will move with a gentle tap of the mallet and only in the direction you tap.
Crack the screws loose so that they still grip and tap the striker toward the outside, maybe a 1/16 or 1/8", nip up the screws (important) and try the door.
HTH
50 Shades of Pennine Grey
Post #960994 8th Aug 2022 12:28pm
Leamreject
That doesn’t sound right especially as the doors don’t sit anything like flush currently. Surely that type of adjustment would make the door sit even prouder than they do now. Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #960995 8th Aug 2022 12:34pm
Mo Murphy
Get it latching easily and see how the set is then. It's a 5 minute job and datum to then work from.
Once it's latching then we can discuss how it's set and adjust further. I don't think it needs the expense of new seals.
Post #960997 8th Aug 2022 12:47pm
Leamreject
Might be best to removed the seal completely to check how the door sits and then work from
that. Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #961001 8th Aug 2022 1:31pm
Retroanaconda
It’s also very common for defender doors to be slightly bowed inwards at the top and bottom - this has the effect of causing the door to be hard to close as the door latches at the middle point and so you have to effectively flex the door straight in order for it to do so. The fix is to very gently bend the door so it is straighter and matches the profile of the tub and hardtop.
My passenger door is like this so needs a firm push to close but I haven’t worked up the courage to try bending it yet!
Post #961005 8th Aug 2022 2:01pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
Is there any play in the hinges as that will affect the swing of the door
Post #961017 8th Aug 2022 3:48pm
Leamreject
A very tidy example…. Thumbs Up Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #961023 8th Aug 2022 4:12pm
Soulrider911
Leamreject wrote:
Might be best to remove the seal completely to check how the door sits and then work from
that.
Thank you for all the replies, and suggestions. What Leamreject said is exactly what I was thinking. when I look closely at the door my assumption is the seal is causing the problem in some way or another. The catch is working... and I would like to not move it out as was stated that would make the gap even larger... if anything I would love to shrink the door gap.
Oh, and that video is amazing and VERY telling... pushing on my seals... they are for sure not OEM... they are pretty tough rubber. I am inclined to try some new OEM seals... I have a strong suspicion that will really help 1989 Defender 90
Post #961027 8th Aug 2022 4:55pm
Linds Hanson
Fit new Genuine door seals and new Genuine door catches in doors with unworn strkers and hinges. With this setup the doors will click closed with a gentle shove. There is no other way
Post #961032 8th Aug 2022 5:52pm
Leamreject
On this topic I would strongly agree Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #961036 8th Aug 2022 6:25pm
Soulrider911
Thank you, this makes sense... so now decision time. My doors are OK, they have some dents, and one has a lot of rust inside, the glass is chipped in both, and there are other little issues. I can buy fully built-up doors that include EVERYTHING. I am almost thinking rather than buying all these individual parts...knowing I still need some rust work done, I think it would be wiser to go with these fully galvanized doors: https://www.sp-4x4.com/BDA710020GALV_Pair_...jwp870.htm
I have talked extensively with them and these are the best you can get for a Defender Smile 1989 Defender 90
Post #961037 8th Aug 2022 6:41pm
Dinnu
My 1988 90 had the same problem. When I removed the seal that is riveted to the sill, it made a huge difference to how the door closed. I could also adjust the latch more inwards, so door sat better with the tub. Probably the door camber as stated earlier. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #961051 8th Aug 2022 8:59pm
Soulrider911
Which seal is riveted? On mine I can just pull the whole thing off? 1989 Defender 90
Post #961052 8th Aug 2022 9:33pm
