Home > Puma (Tdci) > 2.2 cutting out
RobKeay
2.2 cutting out
Have been having a problem for a week or so.
The puma 2.2 cuts out when off the power. It starts straight back up. But the engine light comes on.
Plugged it in and said maf sensor.
Changed air filter and maf sensor. Ran for a few days no problem ( 100 or so miles).
It’s done it again. Has anyone any pointers please.
Post #958416 15th Jul 2022 1:26pm
Dinnu
Have you re plugged it in? Still MAF related? Could it be wiring to the MAF rather the MAF itself? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958425 15th Jul 2022 2:19pm
RobKeay
I’ll have a look at the wiring.
Post #958433 15th Jul 2022 3:34pm
Ianh
Check intercooler to see if crimped seams at the side have split, generally lower left hand seam as you look at it from the front. Also check hose from turbo to IC, IC to metal tube, metal tube to inlet manifold for splits .
See https://www.defender2.net/forum/topic84115.html
Post #958490 16th Jul 2022 1:15am
RobKeay
I’ll have a look thanks for that
Post #958585 17th Jul 2022 9:07am
RobKeay
Any ideas gratefully received.
The 2.2 90 still cuts out. Only slowing down and now only with a heavy trailer.
Post #960638 5th Aug 2022 12:22pm
Ianh
Assuming you have checked IC, hoses and clamps and they are ok, have you had any EGR related DTC’s I.e P0401 ?
Also worth removing the MAP and the Air Charge Sensor, give them a clean and check the connectors and wiring.
Ps is the new MAF a gen LR part ? Some aftermarket ones have had issues, I would also double check the MAF connector wiring, if there is an intermittent issue it may have been resolved for a short while by removing and reconnecting the connector when fitting the new MAF but now showing again.
Post #960641 5th Aug 2022 12:47pm
RobKeay
I can’t see anything. Going to get it checked out.
Yes it is a non gen maf sensor.
Why is the engine cutting out rather than going into limp home mode?
Post #960897 7th Aug 2022 10:07am
